Aruba - clearpass or External CapitvePortal POST HTTPS doesn't work
  • 1.  Aruba - clearpass or External CapitvePortal POST HTTPS doesn't work
    Posted May 24, 2019 09:40 AM
    I would like to configure an external captiveportal for my guest Users.
    So, I configure a new SSID assigneted to a new vlan.
    My initiale role is a MySSID-guest-logon :
    user-role public-portail-guest-logon
    captive-portal "Alsatis-Public-Portail"
    access-list session global-sacl
    access-list session hm_whitelist
    access-list session logon-control
    access-list session captiveportal
    access-list session apprf-public-portail-guest-logon-sacl
    access-list session v6-logon-control
    access-list session captiveportal6
    My problem is that when I use http for authentication on my captive portal webpage, it works.
    But I would like to use https for authentication, but it does not work.
    Thank for your help,
    Best Regard
  • 2.  RE: Aruba - clearpass or External CapitvePortal POST HTTPS doesn't work
    MVP EXPERT
    Posted May 24, 2019 09:53 AM
    What is the error that you are seeing? Have you replaced the default certificates?
  • 3.  RE: Aruba - clearpass or External CapitvePortal POST HTTPS doesn't work
    Posted May 24, 2019 09:59 AM
    the problem is that the post request doesn't work. I see a webpage who asks me to open the authentication web page, and this in a loop.
    When I use http for authentification, I'm redirected on webpage "IPController/cgi-bin/login" and the radius request is initiated.
  • 4.  RE: Aruba - clearpass or External CapitvePortal POST HTTPS doesn't work
    MVP EXPERT
    Posted May 26, 2019 05:17 AM
    I've seen this before and it was due to certificate issues (Guest browser didn't trust the certificate on the controller) so it broke the HTTPS port. Are all of the certificates on the Controller and CPPM valid and trusted? Is the CN names correct and matching any DNS records/controllers?
