  • 1.  Aruba cloud authentication for 802.1x
    Posted Jun 20, 2024 12:17 PM
    Hi All,
    I know that today we can use cloud authentication for APs, WPA2/3 Enterprise, and I have seen there was an online session talking about Cloud Identity and integration with Azure AD/Google Workspace for EAP-TLS authentication, but I can't find any recorded video.
    My question is, does Aruba Central cloud authentication support 802.1x for switches managed by Aruba Central?
  • 2.  RE: Aruba cloud authentication for 802.1x
    Posted Jun 20, 2024 12:20 PM
    Yes, Cloud Auth supports 802.1x (EAP-TLS only) with both wired and wireless infra. Certificate provisioning has to be done through Aruba Onboard app. This video covers both wired and wireless configuration: https://www.youtube.com/watch?v=HvuarP200pI
  • 3.  RE: Aruba cloud authentication for 802.1x
    Posted Oct 17, 2024 09:15 PM
    Hi !
    Thanks for the video link !
    One question though, does that work only for user authentication or we can also use device groups in azure to push certificates and authenticates devices, not just the users? (In the video it seems to be only with users, but I don't want to have users bringing their personnal computers on the EPA-TLS 802.1X SSID...) Also this  means that if I disconnect from my windows for example, the computer won't be authenticated and thus not receivinf any e-mails or so...
    Thanks !
  • 4.  RE: Aruba cloud authentication for 802.1x
    Posted 16 days ago
    Is there support for wired Cloud Auth for AOS-S switches?  The very useful video you link to only describes how to do this with AOS-CX, and I can't seem to find any corresponding ways to add Cloud Auth in the GUI for AOS-S.
  • 5.  RE: Aruba cloud authentication for 802.1x
    Posted 16 days ago
    I believe only CX switches are supported.
