Aruba controller 6000-400 support with AP-325
  • 1.  Aruba controller 6000-400 support with AP-325
    Posted Nov 22, 2018 04:34 AM
    Hi All,
    I wanted to confirm if the aruba controller 6000-400 base supports ap-325 to function, controller firmware id 6.4.3.2 as per the EOL 6000 should support 6.4.x and ap-325 will support 6.4.4.x.
    all the 200 series are eno of sale
    please help me and clarify so accordingly we can procure the APs.
    Nagaraj
  • 2.  RE: Aruba controller 6000-400 support with AP-325
    Posted Nov 22, 2018 05:43 AM
    It will just barely support them.   You should get a 7210 or 7220 to replace the 6000, instead.  Why? Because there are bug fixes and features in 6.5.x for the AP-325 that you would not get if you have the 6000 series.
  • 3.  RE: Aruba controller 6000-400 support with AP-325
    Posted Nov 22, 2018 06:01 AM
    Already customer have 6000-400 controller and about 450 aps as they want to few 30 more aps at present there no plan of upgrade the controller but if ap-325 support maybe in next 6 months time we can upgrade controller of 7200 series, please suggest if the 6000 controller support the Ap-325.
  • 4.  RE: Aruba controller 6000-400 support with AP-325
    Posted Nov 30, 2018 04:24 AM
    once the upgrade of hte controller to the 6.4 latest it shaws the supported ap list in the supported ap in hte maintanance coloumn
