Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
  • 1.  Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 02, 2012 03:58 AM
    Hello people,
    i'm facing this problem..My standalone controller with 4 ap directly connected, they were "down" for an unknow reason and i've commit a Purge command in Campup Whitelist.
    Control plane security is disabled.
    After reboot, no ap is present (no "up" , no "down" , no under "campus ap whitelist"...)
    Checking configuration, now i can see on default vlan there's DHCP = none
    This is incorrect! My 4 ap takes ip from network dhcp (...12.101)
    Trying to set up it again, but nothing to do! There's ever DHCP = none, also after reboot and writing config
    Can u help me please?
    aruba 6.0.1.0
    thanks!
    Nanoweb
  • 2.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 02, 2012 06:18 AM
    Can you upgrade the code on your controller to the latest?  6.0.1.0 is much older and could have issues saving the DHCP scope.
  • 3.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 03, 2012 04:30 AM
    i think upgrading release is really important, but now i can't.
    (can u provide a link with detailed information to upgrade release?)
    to modify dhcp setting for default vlan, the only way is do CONTROLLER WIZARD?
    cannot manually (or by command line) modify dhcp setting for vlan1, is possible?
    Thanks..
  • 4.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 03, 2012 07:26 AM
    Thanks..
    Yes, you can manually modify the DHCP setting.  On the controller go to Configuration> Network> IP.  There will be a DHCP server tab.
  • 5.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 03, 2012 01:36 PM
    i think there is possible only for other Vlan, no for NATIVE VLAN...
  • 6.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 03, 2012 01:46 PM
    To upgrade you have to visit the support.arubanetworks.com site and login with your credentials.
    The files will be there to a) upgrade and b) walk you through the procedure to do so (its 5 mouseclicks or less)
    Once you have upgraded I would recommend re-tackling this item.
    just to clarify are you trying to get DHCP from an external server on your network, or make the controller into a DHCP server for your directly connected APs ?
  • 7.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 24, 2012 06:48 AM
    Hi, thanks for ur time and sorry, I'm in late...
    Proble is maybe effect of PURGE command with ap connected for my 4 ap.
    Clicking by PURGE button there was a warning , something like "no commit with ap connected!!"
    I've clicked same...   :-(
    Now i have fear ap are in bad status, so after software upgrade for controller, if problem persist, i need to reset my aps!!
    Can i use ethernet cable instead consolle cable to perform a reset?
    Where i can find info to perform an ap reset?
    M
  • 8.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 24, 2012 06:52 AM
    You can only use the console cable to reset.  Do NOT use the purge command.
    Configure your console at 9600, N, 8,1 and plug into the console port of the access point.
    Interrupt the boot cycle when it says "press enter...."
    At the commandline type "purge" press enter  then type "save" and press enter.
  • 9.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 24, 2012 06:57 AM
    Problem is I've already performed a PURGE command by gui for all my 4 aps!!!!
    Until that moment aps get an ip from external dhcp on network
  • 10.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 24, 2012 06:59 AM
    Allright.
    After doing that, what is your current problem?
  • 11.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 24, 2012 08:49 AM
    no ap in campus whitelist, no ap everywhere
    no saving "relay to external dhcp" option in controller wizard
  • 12.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 24, 2012 09:01 AM
    Okay.
    Do not use the wizard for now.
    You want to relay DHCP information to an external DHCP server.  is this to provide ip addresses to the access points?  Can you describe your topology to me?
  • 13.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 24, 2012 09:04 AM
    network 192.168.15.0
    controller (vlan1) 192.168.15.25
    dhcp server 192.168.15.5
    relay to external dhcp works until my purge command!
    ap receveid correctly an ip from scpo 192.168.15.22 - 25
    now using wizard relay to external option is nt saved!
    if i save and write config, then start wizard again, in dhcp for vlan1 i can find "none" and no "relat to external on 192.168.15.5"
  • 14.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 24, 2012 09:06 AM
    Thank you.
    if you have a DHCP server on the same subnet as the controller and the access points, you do NOT need a relay.  A relay is ONLY needed if your DHCP server is not on the same subnet.
  • 15.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 24, 2012 09:21 AM
    ok...so problem now is PURGE COMMAND i've executed, i think..
    my aps seems to be "banned", "isolated" , "purged"....
  • 16.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 24, 2012 09:23 AM
    Try turning off control plane security:
    Configuration> Control Plane Security> Disabled.  Apply.
  • 17.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 24, 2012 09:28 AM
    was turned off...
  • 18.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 24, 2012 09:32 AM
    Purge only removes access point entries from a whitelist.
    If you do not have control plane security enabled, the whitelist does not matter.
    Console into your APs and keep pressing enter while they boot up until you are at the "apboot>" prompt.
    When you are at that prompt, type "purge", then "save", then "boot".
    You should see them in the controller in a few minutes.
  • 19.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 24, 2012 09:36 AM
    this is a problem for me now, cause ap are high in the wall....
    i don't know what to do.
    maybe first thing is perform update of system release, but i have a problem with account on support.arubanetworking and i cannot obtain the latest firmware
  • 20.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 24, 2012 09:37 AM
    The best thing you can do is SSH into the controller so we can get detailed information about what is going on.
    SSH into the controller;  get into enable mode, then type "show log system 50" and display the output.
  • 21.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 24, 2012 09:45 AM
    show log system 50
    Aug  3 06:23:21  KERNEL: 0:<6>hub 3-0:1.0: 1 port detected
    Aug  3 06:23:21  KERNEL: 0:<6>USB Universal Host Controller Interface driver v2.3
    Aug  3 06:23:21  KERNEL: 0:<6>drivers/usb/class/usblp.c: v0.13: USB Printer Device Class
    driver
    Aug  3 06:23:21  KERNEL: 0:<6>Initializing USB Mass Storage driver...
    Aug  3 06:23:21  KERNEL: 0:<6>USB Mass Storage support registered.
    Aug  3 06:23:21  KERNEL: 0:Intializing BK-3220 I2C Host Adapter...0:done.
    Aug  3 06:23:21  KERNEL: 0:i2c-palm-bk3220: Added I2C Bus 0
    Aug  3 06:23:21  KERNEL: 0:i2c-palm-bk3220: Added I2C Bus 1
    Aug  3 06:23:21  KERNEL: 0:<6>i2c-grenache: using default base 0xbd000000
    Aug  3 06:23:21  KERNEL: 0:Registering powr6at6 I2C Power Trim Controller driver
    Aug  3 06:23:21  KERNEL: 0:Found POWR6AT6 on Palm Chip BK3220 Adapter 0
    Aug  3 06:23:21  KERNEL: 0:Found POWR6AT6 on Grenache I2C_0
    Aug  3 06:23:21  KERNEL: 0:Registering max6640 I2C based Temperature Sensor driver...
    Aug  3 06:23:21  KERNEL: 0:Found MAX6640 on Grenache I2C_0
    Aug  3 06:23:21  KERNEL: 0:Registering Phoenix I2C based RTC driver...
    Aug  3 06:23:21  KERNEL: 0:<6>: Found DS1374 on Palm Chip BK3220 Adapter 0
    Aug  3 06:23:21  KERNEL: 0:Registering Phoenix I2C based TPM driver...
    Aug  3 06:23:21  KERNEL: 0:Registering Broadcom I2C POE driver...
    Aug  3 06:23:21  KERNEL: 0:<6>: Found BCM59103 on Grenache I2C_0
    Aug  3 06:23:21  KERNEL: 0:<6>: Found BCM59103 on Grenache I2C_1
    Aug  3 06:23:21  KERNEL: 0:<6>802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.co
    m>
    Aug  3 06:23:21  KERNEL: 0:<6>All bugs added by David S. Miller <davem@redhat.com>
    Aug  3 06:23:21  KERNEL: 0:flushing more than page size of icache addresses starting @ c0
    0c1000
    Aug  3 06:23:21  KERNEL: 0:<6>drivers/usb/serial/usb-serial.c: USB Serial support registe
    red for generic
    Aug  3 06:23:21  KERNEL: 0:<6>drivers/usb/serial/usb-serial.c: USB Serial Driver core
    0b9000
    red for GSM modem (1-port)
    Aug  3 06:23:21  KERNEL: 0:<6>drivers/usb/serial/option.c: USB Driver for GSM modems: v0.
    7.1
    0b5000
    Aug  3 06:23:21  KERNEL: 0:<4>sierra: Ignoring new-style parameters in presence of obsole
    te ones
    red for Sierra USB modem
    Aug  3 06:23:21  KERNEL: 0:<6>drivers/usb/serial/sierra.c: USB Driver for Sierra Wireless
     USB modems: v.1.2.7
    0d9000
    Aug  3 06:23:21  KERNEL: 0:<4>hso: Ignoring new-style parameters in presence of obsolete
    ones
    Aug  3 06:23:21  KERNEL: 0:<6>hso: drivers/usb/serial/hso.c: 1.2 Option Wireless
    Aug  3 06:23:21  KERNEL: 0:<6>hso: Registering procfs
    Aug  3 06:23:21  KERNEL: g obsolete setsockopt SO_BSDCOMPAT
    Aug  3 06:23:21  KERNEL: 0:TPM driver running in 3203 mode
    Aug  3 06:23:21  KERNEL: 0:<4>process `soed' is using obsolete setsockopt SO_BSDCOMPAT
    Aug 3 06:23:22 :399816:  <ERRS> |fpapps|  poe download start
    Aug 3 06:23:56 :306510:  <WARN> |publisher|  Dropping message from 8214 for service '51 (
    service not found)'
    Aug 3 06:23:56 :306510:  <WARN> |publisher|  Dropping message from 8214 for service 'aaa-
    idle-user-timeout (service not found)'
    Aug 3 06:24:02 :399816:  <ERRS> |nanny|  Received the PAPI_APP_SPAWN_PROC Message
    Aug  3 06:24:04  KERNEL: 1:<4>process `snmpd' is using obsolete setsockopt SO_BSDCOMPAT
    Aug 3 06:24:05 :306510:  <WARN> |publisher|  Dropping message from 8214 for service '51 (
    service not found)'
    Aug 3 06:24:08 :325022:  <ERRS> |authmgr|  Bogus VLAN ID:4095 received.
    Aug  3 06:24:08  KERNEL: 1:<4>process `trapd' is using obsolete setsockopt SO_BSDCOMPAT
    Aug 3 06:24:09 :399803:  <ERRS> |msghh|  An internal system error has occurred at file ms
    ghh.c function msghh_papi_rcv_cb line 79 error Unexpected message from 127.0.0.1:8405 cod
    e 0.
    Aug 3 06:24:20 :304001:  <ERRS> |stm|  Unexpected stm (Station management) runtime error
    at data_path_handler, 641, data_path_handler: recv - Network is down
  • 22.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 24, 2012 09:48 AM
    The logs do not say anything.  Is there any way to power-cycle the access points?  can you see from the DHCP server if they are getting an ip address?
  • 23.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 24, 2012 09:59 AM
    no evidence on dhcp server.
    ap are not receiving a valid ip.
    are u sure PURGE COMMAND remove only from campus whitelist?
    why the warning in attachment?
  • 24.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 24, 2012 10:07 AM
    When did you turn off control plane security?  A device would only end up in there, if control plane security is on.  Are the access points on the same layer2 VLAN as the controller?  Can you power cycle them so that they can get a new ip address.
    The warning only applies if:
    - you have control plane security on
  • 25.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 24, 2012 10:14 AM
    -control plane was turned off two months ago....ap have worked for two months regularly after that
    -ap are on the same network of controller
    -i can reboot controller, but what i have to do then to check power cycle?
  • 26.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 24, 2012 10:16 AM
    Okay.
    You should not have to reboot the controller.  If an AP power cycled, it should show up in "show log system" output.  Did the access points have static ip addresses or did they use DHCP?  At minimum, they should be requesting an ip address if they are power cycled....
  • 27.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 24, 2012 10:33 AM
    how can i power cycle a single ap?
  • 28.  RE: Aruba Controller 620, not saving RELAY EXTERNAL DHCP for default vlan
    Posted Aug 24, 2012 12:19 PM
    If it does not show up on the controller, you would need to power cycle the AP manually by unplugging it.
