Location Services
last person joined: 10 days ago
Location-based mobile app development and Bluetooth-based asset tracking with Meridian. Gathering analytics and business intelligence from Wi-Fi with Analytics and Location Engine (ALE).
Aruba Controller 620 Upgrade error
  • 1.  Aruba Controller 620 Upgrade error
    Posted Apr 03, 2014 10:25 PM
    Upgrade the OS I get the followingerror
    Not enough flash/memory available (70 MB needed).
    Please clean flash and try again.
    (Aruba620) # show  storage
    Filesystem                Size      Used Available Use% Mounted on
    /dev/mtdblock11         156.0M    122.2M     33.8M  78% /flash
    none                    300.0M      2.4M    297.6M   1% /tmp
    /dev/mtdblock11         156.0M    122.2M     33.8M  78% /mswitch/sap/images
    /dev/mtdblock9           50.0M     50.0M         0 100% /mnt/img0
    /dev/mtdblock10          50.0M     35.3M     14.7M  71% /mnt/img1
    /img0 Utilizationis 100%,  Upgrade /mnt/img1 appears exactly the same error
    .Now do not konw how to solve this problem
    Thanks.
  • 2.  RE: Aruba Controller 620 Upgrade error
    Posted Apr 04, 2014 12:11 AM
    The message indicates you don't have enough storage on your flash to do the upgrade.  You'll need to copy off/delete any files you do not need.  The following is from the Release Notes.  Check to see if there is something you can move off.
    If the output of the show storage command indicates that insufficient flash memory space is available, you must
    free up additional memory. Any controller logs, crash data, or flash backups should be copied to a location off the
    controller, then deleted from the controller to free up flash space. You can delete the following files from the controller
    to free memory before upgrading:
    --Crash Data: Issue the tar crash command to compress crash files to a file named crash.tar. Use the
    procedures described in Backing up Critical Data on page 75 to copy the crash.tar file to an external server, then
    issue the tar clean crash command to delete the file from the controller.
    ArubaOS 6.3.1.3 | Release Notes Upgrade Procedures | 7475 | Upgrade Procedures ArubaOS 6.3.1.3 | Release Notes
    --Flash Backups: Use the procedures described in Backing up Critical Data on page 75 to back up the flash
    directory to a file named flash.tar.gz, then issue the tar clean flash command to delete the file from the
    controller.
    --Log files: Issue the tar logs command to compress log files to a file named logs.tar. Use the procedures
    described in Backing up Critical Data on page 75 to copy the logs.tar file to an external server, then issue the tar
    clean logs command to delete the file from the controller.
    Also, what version are you on and upgrading to?
