Aruba Controller 620 with 16 Remote AP Support
  • 1.  Aruba Controller 620 with 16 Remote AP Support
    Posted Sep 25, 2013 11:07 AM
    Hello together,
    as far as I know the 620 controller supported up to 32 remote ap's. My ACMP was in Version 5 so maybe this changed since version 6.x? Because actually the Controller Matrix talks about 8 CAPs and RAPs?!
    Now I have the issue that a customer with 620 controller want's to use 9 APs. Is this really a physical limitation, oder is the usage of 9 RAPs still possible, but not recommended?
    Thanks in advance!
    PAW
  • 2.  RE: Aruba Controller 620 with 16 Remote AP Support
    Posted Sep 25, 2013 11:10 AM
    In version 6.x, the RAP limit on the 620 is 8.
  • 3.  RE: Aruba Controller 620 with 16 Remote AP Support
    Posted Sep 25, 2013 12:18 PM
    version 6.2 more specifically.  6.1 can still have 32 RAP on a 620 controller.
  • 4.  RE: Aruba Controller 620 with 16 Remote AP Support
    Posted Sep 27, 2013 08:51 AM
    Edit:
    I have Verson 6.1.3.6 installed acutally. But the 9 th AP is flagged with "IL" so unlicensed and inactive.
    Actually I have 8 running APs. So I have to provision one of the running CAP as RAP and then I can add another RAP, right?
  • 5.  RE: Aruba Controller 620 with 16 Remote AP Support
    Posted Sep 27, 2013 09:13 AM
    yeah that's right.
    8 CAPs or 7 CAPs + 4 RAPs or 6 CAPs + 8 RAPs and so on.
    You do still need the AP licence though.
  • 6.  RE: Aruba Controller 620 with 16 Remote AP Support
    Posted Oct 29, 2014 05:26 AM
    facing the same Problem, can somebody tell me whats the supported APs in 6.4?
    I have 6.1.3.6 running
    12 AP License
    7 CAPs
    3 RAPs
    Remaining
    0 CAPs
    1 RAPs
    the APs are AP93 and i have to install 2x AP103. Therefore i have to update to 6.4 i think. How does the Supported AP change then?
  • 7.  RE: Aruba Controller 620 with 16 Remote AP Support
    Posted Apr 28, 2015 02:30 PM
    On the 620 controller, with any firmware on a newer line than 6.1.x, you are hardware limited to 8 AP's whether they are RAP or CAP.  So if you update to 6.4.x code, you'll be able to run less AP's than currently, not more.  You're looking at upgrading to a new controller.  The good news is that the new base model, the 7005, supports 16 APs.  The 600 series controllers don't support all of the 6.3 and 6.4 features anyway.
    As I understand it, the trade off with the newer code is that:
    • Downside: RAP's and CAP's have the same value, so whatever controller you own, the old CAP hardware limit, is the new all AP limit.  So admins can't skirt the AP limit by provisioning them as RAPs anymore.
    • Upside: On 6.3 and newer there is License Pooling.   So you don't have to buy all those duplicate licenses anymore for redundancy.  Just set your Master controller as the "license server" for the master controller's domain, and your controllers can share licenses for redundancy now.  So if one controller fails, it gives up the licenses it was consuming, and the backup LMS controller can take start using those licenses (just make sure that controller's hardware limit supports your total number of APs :-D ).
