This WLAN platform matrix is also useful to find which APs and controllers are supported with what software versions.
Original Message:
Sent: Mar 06, 2023 11:33 AM
Subject: Aruba Controller 7005 support maximum firmware for Access Point
Sorry I should have been more clear on that. As of that post, all of the most recent APs. Always take a look at release notes to check that your managed APs are compatible.
Dustin Burns
ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
Original Message:
Sent: Mar 06, 2023 10:55 AM
- "latest 8.11. With that you can also support all available APs"
Available to purchase ?, or to use, ?,
(the 8.11 limit the whole range of AP-models dramatically!)
Steinar
