Aruba Controller 7005 support maximum firmware for Access Point
This thread has been viewed 31 times
  • 1.  Aruba Controller 7005 support maximum firmware for Access Point
    Posted Feb 13, 2023 11:54 AM
    Hi All,
    our office is using Aruba Controller 7005 with running firmware 8.6
    We are expanding our office with 3 new APs.
    What is the maximum firmware that 7005 can support?
    is it able to support access point 8.7 or requires to downgrade of the firmware in order to use?
    Thanks in advance.
  • 2.  RE: Aruba Controller 7005 support maximum firmware for Access Point
    MVP GURU
    Posted Feb 13, 2023 12:51 PM
    Currently the 7005 Controller can run all the way up to the latest 8.11. With that you can also support all available APs. You can look at the release notes for the version of code your running on there and see what AP models are supported.
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022-2023
  • 3.  RE: Aruba Controller 7005 support maximum firmware for Access Point
    Posted 26 days ago
    • "latest 8.11. With that you can also support all available APs"
    Available to purchase ?, or to use, ?,
    (the 8.11 limit the whole range of AP-models dramatically!)
    Steinar
  • 4.  RE: Aruba Controller 7005 support maximum firmware for Access Point
    MVP GURU
    Posted 26 days ago
    Sorry I should have been more clear on that. As of that post, all of the most recent APs. Always take a look at release notes to check that your managed APs are compatible.
    Dustin Burns
  • 5.  RE: Aruba Controller 7005 support maximum firmware for Access Point
    Posted 24 days ago
    This WLAN platform matrix is also useful to find which APs and controllers are supported with what software versions.
  • 6.  RE: Aruba Controller 7005 support maximum firmware for Access Point
    Posted 23 days ago
    Hi, you can use this page as well to figure out which version of software and hardware are supported and when they will reach end of sale/support
    https://www.arubanetworks.com/support-services/end-of-life/#product=access-points&version=0
    I hope this helps.
