Aruba Controller 7010 Initial Setup
This thread has been viewed 51 times
  • 1.  Aruba Controller 7010 Initial Setup
    Posted May 25, 2017 11:54 PM
    we do initial config on controller 7010,after the first configuration finished the controller get reload,and then when the controller is up,the controller back to controller setup :
    here the log from the controller CLI :
    Current choices are:
    System name: Test
    Switch Role: standalone
    VLAN 1 interface IP address: 172.16.0.254
    VLAN 1 interface subnet mask: 255.255.255.0
    Option to configure VLAN 1 interface IPV6 address: no
    Country code: us
    Time Zone: pst-8:0
    Ports shutdown: no
    If you accept the changes the switch will restart!
    Type <ctrl-P> to go back and change answer for any question
    Do you wish to accept the changes (yes|no)yes
    Creating configuration... Done.
    System will now restart!
    Shutdown processing started
    Syncing data....done.
    Time sync [Done]
    Please stand by while rebooting the system.
    Stage 1 Loader 1.0.5.0 (build 56553)
    Built: 2016-09-22 at 05:02:10
    Secure Boot Enabled on the Processor
    Bank: Primary
    CPLD: rev: 3.0 (30:0060|32:0002|33:0000|34:0000|35:0000)
    PRID: 000C1203
    POWER ON RESET CFG:30CC0FF2
    Initialized I2C0 Controller.
    Initialized I2C1 Controller.
    SPD Rev:0x11 DIMM:0 Type:2 Speed:666MHz #Rank:1
    DDR3: Node 0 Channel 0 Mem size = 4096 MB UDIMM
    set freq:666666
    DDR3: Node 0 DRAM frequency 666 MHz
    DDR3: Node 0 CPU frequency 800 MHz
    mtb_ps:125 clock:1500 trc:33 trcd:9 trp:9
    AP3:A0CFFF0 ODTP1:10000
    Board DDR VDD set to 1.5V.
    N:0 CH:0 additional rdlvl rdly:1
    N:0 Ch:0 m:32 s:32 R OK.
    Rank:0 HW WLVL Passed Mask:1FF
    n:0 ch:0 RTT WR:0200
    ===N:0 Ch:0 m:32 s:32 RW OK.
    Node:0 Ch:0 TGE Set Memory:4096 MB value:FF FF -- PASS
    Node:0 Ch:0 TGE Set Memory:4096 MB value:FF 00 -- PASS
    Node:0 Ch:0 TGE Set Memory:4096 MB value:AA 55 -- PASS
    Node:0 Ch:0 TGE Set Memory:4096 MB value:00 00 -- PASS
    DDR3 Initialization Passed.
    NBU0 DRAM BAR0 base: 00000000 limit: 0013f000 xlate: 00000001 node: 00000000 ( 0 MB -> 320 MB, size: 320 MB)
    NBU0 DRAM BAR1 base: 001d0000 limit: 00bff000 xlate: 00090001 node: 00000000 ( 464 MB -> 3072 MB, size: 2608 MB)
    NBU0 DRAM BAR2 base: 00e00000 limit: 0128f000 xlate: 00290001 node: 00000000 ( 3584 MB -> 4752 MB, size: 1168 MB)
    Hit Ctrl + X keys to stop autoboot: 0
    CPBoot image is signed
    Verifying CPBoot checksum...
    CPBoot check passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    ## Starting application at 0x8C100000 ...
    CPBoot 1.0.7.0 (build 56553)
    Built: 2016-09-22 at 04:52:12
    DRAM: 4 GB
    Detected [XLP208 Rev B1 (Secure Boot) ] (6a|6a)
    Flash: 16 MB
    PCIE (B0:D01:F0) : Link up (Gen(1))
    Bank: Primary
    Board: A7010
    CPU: XLP208 Rev B1 (Secure Boot)
    Clock: Core 800 MHz / SoC 800 MHz (30cc0ff2)
    Net: ge-0, ge-2, ge-3, ge-4, ge-1
    Inventory Verification: PASS
    Hit Ctrl + X key to stop autoboot: 0
    USB0: setting speed to USB_SPEED_HIGH
    2 USB Device(s) found
    #1 Storage Device(s) found
    ##Loading image 0:0######################################
    Image is signed; verifying checksum...
    passed
    Signer Cert OK
    Policy Cert OK
    0:xlp_napi_vc_mask 0xf
    0:sae frequency is 500
    0:nlm_hal_set_sae_engine_sel: xlp2xx return
    0:-- SAE Frequency set to 500
    0:cde frequency is 333
    0:CDE Frequency set to 333MHz
    0:MSGRING_NAPI: Initializing NLM NAPI subsystem
    Aruba Networks
    ArubaOS Version 6.4.3.4 (build 51619 / label #51619)
    Built by p4build@formentera.arubanetworks.com on 2015-09-10 at 20:14:07 PDT (gcc version 4.4.5)
    Copyright (c) 2002-2015, Aruba Networks, Inc.
    <<<<< Welcome to Aruba Networks - Aruba A7010 >>>>>
    Probing for EEPROM devices [ OK ]
    Probing for real-time clock [ OK ]
    Initializing LCD module [ OK ]
    Uncompressing core image files [ OK ]
    Extracting corefs [ OK ]
    Enabling watchdog [ OK ]
    Starting device manager [ OK ]
    Performing eUSB Flash fast test... [ DONE ]
    [ OK ]
    Mounting flash [ OK ]
    PoE firmware [ OK ]
    Checking system inventory [ OK ]
    Installing ancillary FS [ OK ]
    Performing integrity check on ancillary partition 0 [ OK ]
    Reboot Cause: User reboot (Intent:cause:register 78:86:50:60)
    Starting syslog service [ OK ]
    Restoring the database [ OK ]
    Generating SSH keys [ OK ]
    Initializing TPM and certificates [ OK ]
    Checking for configuration upgrade [ OK: Intra-Version Upgrade ]
    Starting OS services [ OK ]
    Starting auto provisioning
    Using port gigabitethernet 0/0/15 for auto provisioning
    Initiated DHCP, awaiting DHCP response
    Auto-provisioning is in progress. Choose one of the following options to override or debug...
    'enable-debug' : Enable auto-provisioning debug logs
    'disable-debug' : Disable auto-provisioning debug logs
    'mini-setup' : Stop auto-provisioning and start mini setup dialog for branch role
    'full-setup' : Stop auto-provisioning and start full setup dialog for any role
    Enter Option (partial string is acceptable): full-setup
    please help us to resolve this issue..
    Thank You All.
  • 2.  RE: Aruba Controller 7010 Initial Setup
    MVP EXPERT
    Posted May 26, 2017 03:33 AM
    Do you have any USB storage devices connected? Can you try removing these and starting the initial setup again?
  • 3.  RE: Aruba Controller 7010 Initial Setup
    Posted May 26, 2017 03:41 AM
    Hi Craig,
    we do not use any USB storage,previously we do factory default to this controller,because we want change from mini setup to full setup,is there any step might have missed?
    Thank You.
  • 4.  RE: Aruba Controller 7010 Initial Setup
    Posted May 26, 2017 05:55 AM
    Did you set the cfgfile variable?
  • 5.  RE: Aruba Controller 7010 Initial Setup
    Posted May 26, 2017 07:35 AM
    Hi Colin,
    Yes,previously we set cfgfile variable to do factory reset,is the issue happen regarding that configuration?
    Thank You.
  • 6.  RE: Aruba Controller 7010 Initial Setup
    Posted May 26, 2017 07:36 AM
    Yes.  You need to "unset" the cfgfile variable like this:
    apboot> setenv cfgfile
    apboot> save
    apboot> boot
  • 7.  RE: Aruba Controller 7010 Initial Setup
    Posted May 26, 2017 07:48 AM
    Hi colin,
    I will try this config later,i will inform if this can solving our problem.
    Thank You.
  • 8.  RE: Aruba Controller 7010 Initial Setup
    Posted May 26, 2017 07:49 AM
  • 9.  RE: Aruba Controller 7010 Initial Setup
    Posted May 29, 2017 01:33 AM
    Hi Colin,
    It's working great,thank you for help.
