The 7205 is compatible with all Aruba APs. It is the code version that matters. You can check the release notes of 8.9 and you will see what APs are supported. 8.9 release notes here (start at page 9):
https://www.arubanetworks.com/techdocs/ArubaOS-8.x-Books/Release-Notes/89/ArubaOS-8.9.0.3-Release-Notes.pdf------------------------------
Dustin Burns
ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
Original Message:
Sent: Oct 20, 2022 02:49 AM
Subject: Aruba Controller 7205 Compatible ap's
Is Aruba AP- 205 compatibility with Aruba Controller 7205 with AurbaOS 8.9 version?
Can I get any reference link and list of Compatible AP's with Aruba Controller 7205?
Rakesh.Biradar
