Aruba Controller A7010 Watchdog problem Mad Dog!!
  • 1.  Aruba Controller A7010 Watchdog problem Mad Dog!!
    Posted Jul 05, 2018 03:09 AM
    Stage 1 Loader 1.0.5.0 (build 56553)
    Built: 2016-09-22 at 05:02:10
    Secure Boot Enabled on the Processor
    Bank: Secondary Watchdog
    CPLD: rev: 3.0 (30:0068|32:0004|33:0000|34:0000|35:0000)
    PRID: 000C1203
    POWER ON RESET CFG:30CC0FF2
    Initialized I2C0 Controller.
    Initialized I2C1 Controller.
    SPD Rev:0x11 DIMM:0 Type:2 Speed:666MHz #Rank:1
    DDR3: Node 0 Channel 0 Mem size = 4096 MB UDIMM
    set freq:666666
    DDR3: Node 0 DRAM frequency 666 MHz
    DDR3: Node 0 CPU frequency 800 MHz
    mtb_ps:125 clock:1500 trc:33 trcd:9 trp:9
    AP3:A0CFFF0 ODTP1:10000
    Board DDR VDD set to 1.5V.
    N:0 CH:0 additional rdlvl rdly:1
    N:0 Ch:0 m:32 s:32 R OK.
    Rank:0 HW WLVL Passed Mask:1FF
    n:0 ch:0 RTT WR:0200
    ===N:0 Ch:0 m:32 s:32 RW OK.
    Node:0 Ch:0 TGE Set Memory:4096 MB value:FF FF -- PASS
    Node:0 Ch:0 TGE Set Memory:4096 MB value:FF 00 -- PASS
    Node:0 Ch:0 TGE Set Memory:4096 MB value:AA 55 -- PASS
    Node:0 Ch:0 TGE Set Memory:4096 MB value:00 00 -- PASS
    DDR3 Initialization Passed.
    NBU0 DRAM BAR0 base: 00000000 limit: 0013f000 xlate: 00000001 node: 00000000 ( 0 MB -> 320 MB, size: 320 MB)
    NBU0 DRAM BAR1 base: 001d0000 limit: 00bff000 xlate: 00090001 node: 00000000 ( 464 MB -> 3072 MB, size: 2608 MB)
    NBU0 DRAM BAR2 base: 00e00000 limit: 0128f000 xlate: 00290001 node: 00000000 ( 3584 MB -> 4752 MB, size: 1168 MB)
    Hit Ctrl + X keys to stop autoboot: 0
    CPBoot image is signed
    Verifying CPBoot checksum...
    CPBoot check passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    ## Starting application at 0x8C100000 ...
    CPBoot 1.0.7.0 (build 56553)
    Built: 2016-09-22 at 04:52:12
    DRAM: 4 GB
    Detected [XLP208 Rev B1 (Secure Boot) ] (6a|6a)
    Flash: 16 MB
    Watchdog caused the previous reset. So Running Watchdog Framework
    Watchdog reset caused in cpboot context
    We even can not step in cpboot, we can go into cpxload only now. What can we do now ? We just upgrade from AOS6.5 to AOS8.2.1 why like this ?
    cpxload# help
    barinit - barinit
    cmp - memory comparing
    cp - memory copy
    cpboot - execute CPBoot
    cpld - cpld : read/write CPLD registers
    crc16 - compute crc16
    ddr - show ddr registers
    ddrinit - ddrinit
    ddrrd - read ddr registers
    ddrwr - write ddr registers
    except - Exception Handler Test
    help - print command description/usage
    i2c - i2c access
    lcm - initialize the LCM
    loop - loop cmds
    md - memory display
    memecc - memecc
    memsi - full memory test
    mfcr - mfcr: rd registers
    mtcr - mtcr: write registers
    mtest - memory test
    mw - memory write (fill)
    phy - show ddr phy registers
    phyrd - read ddr phy registers
    phywr - write ddr phy registers
    printenv- print environment variables
    rd - rd registers
    rw - write registers
    spd - show ddr3 spd data
    tge - tge cmds
    cpxload#
    System will be rebooted in about 1 seconds...
  • 2.  RE: Aruba Controller A7010 Watchdog problem Mad Dog!!
    Posted Jul 05, 2018 03:40 AM
    Mad Dog alway reboot , I even can not go into cpboot
    DRAM: 4 GB
    CPLD: rev: 3.0 (30:8008|32:0004|33:0000|34:0000|35:0000)
    Flash: 16 MB
    DRAM: 4 GB
    Flash: 16 MB
    DRAM: 4 GB
    Flash: 16 MB
  • 3.  RE: Aruba Controller A7010 Watchdog problem Mad Dog!!
    Posted Jul 05, 2018 05:10 AM
    Hi Lin,
    If you have the flashbackup available, you can try to check if factory reset option is working from the LCD menu.
  • 4.  RE: Aruba Controller A7010 Watchdog problem Mad Dog!!
    Posted Jul 05, 2018 07:49 AM
    are sure the lcd is work without AOS ? We even can not go into cpboot
