Aruba controller captive portal redirection
This thread has been viewed 23 times
  • 1.  Aruba controller captive portal redirection
    Posted Feb 17, 2021 02:38 PM
    i have 7210 controller and i need to configure captive portal on SSID with preshared key authentication , For example : after connect to SSID via password i need to redirect to captive portal to download certificate
    Ahmed Elshindidy
  • 2.  RE: Aruba controller captive portal redirection
    MVP EXPERT
    Posted Feb 18, 2021 03:46 AM
    You can do this with the following
    - Create your AAA Authentication Captive Portal
    https://www.arubanetworks.com/techdocs/ArubaOS_85_Web_Help/Content/arubaos-solutions/captive-portal/capt-port-auth.htm
    - Create your WLAN SSID PSK Profile
    https://www.arubanetworks.com/techdocs/ArubaOS_85_Web_Help/Content/arubaos-solutions/virtual-ap/wlan-ssid-prof.htm?Highlight=wlan%20ssid%20profile
    -Add the Captive Portal to your Initial User Role
    https://www.arubanetworks.com/techdocs/ArubaOS_85_Web_Help/Content/arubaos-solutions/roles-policies/user-role.htm?Highlight=user%20role
    - Add 'logon' User Role (which contains your Captive Portal) to your AAA Profile
    https://www.arubanetworks.com/techdocs/ArubaOS_85_Web_Help/Content/arubaos-solutions/roles-policies/assi-user-role.htm?Highlight=initial%20role
    Then add the AAA Profile, WLAN SSID Profile and any other configuration you need to the VAP.
    https://www.arubanetworks.com/techdocs/ArubaOS_85_Web_Help/Content/arubaos-solutions/virtual-ap/conf-vap-prof.htm?Highlight=virtual%20ap%20profile
    Craig Syme
