last person joined: 3 hours ago
aruba controller in Master-local setup
  • 1.  aruba controller in Master-local setup
    Posted Nov 11, 2013 09:27 AM
    Is there anyway to force all AP to move to Local controller without rebooting master controller?  I had all AP on local controller but we lost connectivity to local made all ap report to master.
    Thank you
  • 2.  RE: aruba controller in Master-local setup
    Posted Nov 11, 2013 09:30 AM
    Are you using VRRP or LMS?
    - You can turn on VRRP preemption in the VRRP settings.
    - You can turn on LMS preemption in the AP system profile.
  • 3.  RE: aruba controller in Master-local setup
    Posted Nov 11, 2013 09:35 AM
    I am using LMS.
    I just turned on LMS preemption.
  • 4.  RE: aruba controller in Master-local setup
    Posted Nov 11, 2013 09:39 AM
    Since it was turned on after the failover event, you may have to swap the LMS and Backup LMS IPs to trigger the failover, then switch them back.
  • 5.  RE: aruba controller in Master-local setup
    Posted Nov 11, 2013 09:42 AM
    worked.
    Thank you
