Aruba Controller is not pinging your's gateway
  • 1.  Aruba Controller is not pinging your's gateway
    Posted Dec 06, 2018 02:23 PM
    Hi, i'm configuring a Aruba Controller 620, it has 2 VLANs, VLAN 1 is default and VLAN 80, that is connect to a DHCP server that is your gateway, it is getting the correct DHCP configurations, but is nothing pinging the gateway.
    It is a Firewall problem? Please help me!!!
  • 2.  RE: Aruba Controller is not pinging your's gateway
    Posted Dec 06, 2018 04:01 PM
    Hi
    Are your wifi clients on vlan 80 and not able to ping the gateway?
    Or is your 620 controller also on vlan 80 and not able to ping the gateway?
