I have two controllers (aruba 7720 ver 8.10) that are managed by 2 Conductors (ArubaMM-VA ver 8.10) and as part of the pen test it has been flagged up that the loginsession timeout needs to be setup to less than 6 minutes.
I have been able to set this on the Conductors via the CLI. Some how one of the controllers has this setup (not via CLI) but cannot see the option to set it for the other controller. If i try to go into config mode on the controllers it rightly says that this is managed to the conductor - i just don't see where.
Can go into disaster mode on the controller put on the command but once I disable this the command disables.
I know I have to do from the conductor but were is it?
