  • 1.  Aruba Controller Password Reset Jan06-Tutorial
    Posted Jan 06, 2014 01:55 AM
    If you have forgotten or lost your Aruba Controllers Password it can be reset following the bellow steps.
    1. Connect to the cotroller via Console cable
    2. Login using "password" as the user name and use "forgetme!" as the password.
    3. Type "enable" to enter the enable mode
    4. Type "conf term" to enter configuration mode
    5. In configuration mode, enter ‘mgmt-user admin root’ and reset the password
    6. Re-login using the new admin password you just set.
    7. Enter "enable" and then "conf term" to enter configuration mode
    8. Type ‘enable secret’ reset the enable mode password.
    9. Lastly perform a "write mem" to save your new passwords and make it persistent
    Example:
    User: password
    Password: forgetme!
    (aruba) >enable
    Password: enable
    (aruba) #configure terminal
    Enter Configuration commands, one per line. End with CNTL/Z
    (aruba) (config) #mgmt-user admin root
    Password:
    Re-Type password:
    (aruba) (config) #exit
    (aruba) #exit
    (aruba) >exit
    User: admin
    Password:
    (aruba) >enable
    Password: enable
    (aruba) (config) #enable secret
    Password:
    Re-Type password:
    (aruba) (config) #write memory
    Please give Kudos if you learnt something new or useful :)
  • 2.  RE: Aruba Controller Password Reset Jan06-Tutorial
    Posted Sep 06, 2016 12:54 AM
    Just want to add on this article, I encounter a problem on Aruba 7005 controller no matter how I change the admin password using the command above it wont work. I did found the following command.
    User: password
    Password:*********
    (Aruba) (config) #no mgmt-user localauth-disable
    (Aruba) (config) #mgmt-user admin root
    Password:********
    Re-Type password:********
    (Aruba) (config) #exit
    (Aruba) #exit
    User:Admin
    Password:*********
    (Aruba) #
    (Aruba) #
  • 3.  RE: Aruba Controller Password Reset Jan06-Tutorial
    Posted Aug 30, 2018 03:31 PM
    OK...
    So everything works..
    I logon .. I reset the admin password..
    I logoff and relog with my new password..
    Smiles..
    So then, I reboot the device..
    I get to the logon prompt..
    I logon in with the with same user/ password combo..
    and Frown.
    I cant login..
    So
    I redo the entire step pattern again..
    USER. Password... PASSWORD. forgetme! ....etc
    Reset the Admin password again..
    Test again.
    Reboot again.
    Frown again..
    How do I keep a smile?
  • 4.  RE: Aruba Controller Password Reset Jan06-Tutorial
    Posted Aug 30, 2018 04:02 PM
    After you login, create another admin user with the role of root and type "write mem".  Login with that new admin user...
  • 5.  RE: Aruba Controller Password Reset Jan06-Tutorial
    Posted Jul 11, 2023 08:01 AM
    Edited by ryh Jul 11, 2023 08:01 AM
    In the Central-managed mode, is there any equivalent command that works to add a user or change the password?
    User: password
    Password:
    (Aruba7005_xx_yy_zz) *#enable
    Invalid input detected at '^' marker.
    (Aruba7005_xx_yy_zz) *#configure t
    This controller is managed by an ACP.
    Configuration changes can only be performed on the ACP.
    (Aruba7005_xx_yy_zz) *#disaster-recovery on
    Error:You do not have permission to execute this command
    ryh
  • 6.  RE: Aruba Controller Password Reset Jan06-Tutorial
    Posted Jul 11, 2023 08:58 AM
    Yes, configure the user and/or password from Central.
  • 7.  RE: Aruba Controller Password Reset Jan06-Tutorial
    Posted Feb 13, 2024 05:06 AM
    What do I do if the gateway lost ocnnection to Central, I don't have the password that was configured in Central,  but I need to reset the password to reconfigure it in disaster recovery mode, so it can gain access to Central again?
    Bjarne
  • 8.  RE: Aruba Controller Password Reset Jan06-Tutorial
    Posted Feb 13, 2024 12:17 PM
    Maybe a hard factory reset of the device would work?  Ideally the settings from Central will properly configure the device again when it connects.
    ryh
