Aruba controller reboot
This thread has been viewed 40 times
  • 1.  Aruba controller reboot
    Posted Feb 27, 2018 08:47 AM
    I have Aruba controllers 7010 (version 6.5.4.3) that gets rebooted (wlsxColdStart Detected),
    From the Webgui, the logs show that the controller was down and back up,
    From CLI, I noticed that the logs were showing (killing dogma and watchdog) before and after the reboot,
    It doesn't really say what caused the reboot,
    Is there some other ways to find out what cause the reboot?
    thanks
    JF
  • 2.  RE: Aruba controller reboot
    Posted Feb 27, 2018 08:58 AM
    Is there a crash.tar file? We are having the same problem and TAC is
    looking into it but we never get a crash.tar file
    *Jon Hutchinson*
    *8B Packer Ave rm 185*
    *Lehigh University(610)758-5099*
  • 3.  RE: Aruba controller reboot
    Posted Feb 27, 2018 09:59 AM
    I ran the command (show switchinfo) from the CLI and I got the result below.
    No crash information avalaible.
    Reboot cause: Power Cycle
  • 4.  RE: Aruba controller reboot
    MVP
    Posted Feb 27, 2018 10:06 AM
    Is the controller connected to a UPS? Did anything else connected to the same device go down?
    ColdStart makes me think it lost power. WarmStart usually indicates a reboot initiated by command.
  • 5.  RE: Aruba controller reboot
    Posted Feb 27, 2018 10:10 AM
    no, there is no UPS connected on that one.
    It seemed that there was a lost of power that caused this
  • 6.  RE: Aruba controller reboot
    MVP
    Posted Feb 27, 2018 10:24 AM
    I would see if you can check a switch or something in the same rack or connected to a close outlet. Check the uptime and see if anything else went down.
    There is a known bug in AOS 6.5.4.3 that causes controller to reboot, but the reason is different, so I don't suspect that to be the issue.
  • 7.  RE: Aruba controller reboot
    Posted Feb 27, 2018 10:28 AM
    Do you have more information on the known bug in AOS 6.5.4.3?
  • 8.  RE: Aruba controller reboot
    Posted Feb 27, 2018 10:37 AM
    Bug id : 167418
    Symptom: A master controller rebooted after DPI was disabled. The log file listed the reason for the event as Reboot Cause: Datapath timeout (SOS Assert) (Intent:cause:register 54:86:50:2). The fix ensures that the controller works as expected.
    Scenario: This issue was observed in controllers running ArubaOS 6.5.3.1.
  • 9.  RE: Aruba controller reboot
    Posted Feb 27, 2018 10:39 AM
    thanks for the info
  • 10.  RE: Aruba controller reboot
    MVP EXPERT
    Posted Feb 27, 2018 10:40 AM
    There's quite a lot of resolved issues in the latest ArubaOS 6.5.4.x release which related to a unexpected reboot due to various reasons. Some of these appear to be written to the log file. The log file won't survive a reboot, do you have a syslog server you could set up in order to capture some logs?
    http://www.arubanetworks.com/techdocs/ArubaOS/6.5.x.x/Default.htm#ReleaseNotes/ResolvedIssues/ResolvedIssues6.5.x.htm%3FTocPath%3D_____4
