Telnet-1,
With tunneled-node, I would first start with the following scaling document:
http://www.arubanetworks.com/pdf/products/matrix-mobility-controller.pdf
Now, the fields you should review are as follows.
Maximum concurrent users/devices
- Tunneled-Node ports and users are not 1:1. A Tunneled-Node port can have many users but use only one tunnel. Therefore you must review this value otherwise it is highly possible to exceed the number of users before exceeding the tunneled ports.
Mobility Access Switch Tunneled Node port
- Each Tunneled-Node port uses one tunnel back to a Mobility Controller. Since a single ArubaStack can have up to 384 ports, be mindful of a Mobility Controller's tunnel capacity to avoid exceeding it.
Firewall throughput
- Given the performance of a Mobility Access Switch or an ArubaStack of Mobility Access Switches, you must pay careful attention to the amount of throughput you are potentially sending to a Mobility Controller.
Maximum campus AP licenses
- A standalone Mobility Access Switch or an ArubaStack consume 1 set of licenses (AP, PEFNG, RFP) so pay attention not to exceed this value.
Now as Tim C. mentioned, you can also use the native role-based access of the switch if you are concerned about the performance impact on your 3200 Mobility Controller.
Best regards,
Madani
