Aruba controller syslog integration with Solarwinds
  • 1.  Aruba controller syslog integration with Solarwinds
    Posted May 18, 2020 05:36 AM
    I'm trying to config syslog on Aruba controller AOS 8  in order to view syslog meaages on Solarwinds server.
    is there any particular port to be used ?
  • 2.  RE: Aruba controller syslog integration with Solarwinds
    Posted May 18, 2020 06:15 AM
    By default it sends output on the standard port 514 if you do not specify.  It should be the same on Solarwinds...  unless I am wrong.
  • 3.  RE: Aruba controller syslog integration with Solarwinds
    Posted May 18, 2020 07:50 AM
    thank you,
    indeed, it's using port 514, now I can see traffic with wireshark and also on Solarwinds.
    One more question, it is possible to select at the 'logging level' tab more than 1 option ? I mean, informational and critical for example.
