Aruba Controller Users lost connectivity and not getting ip address using Guest SSID
  • 1.  Aruba Controller Users lost connectivity and not getting ip address using Guest SSID
    Posted Apr 26, 2017 12:04 AM
    Hi All,.
    Please help to troubleshoot an issue facing by some users at a time.
    Users lost connectvity and getting Apipa ip address while connecting to only Guset SSID.WLC details are below
    AOS-W (MODEL: OAW-4704-US), Version 6.2.1.3.
    This issue is intermittent and occuring from days.
    any kind of help is really appreciated.
  • 2.  RE: Aruba Controller Users lost connectivity and not getting ip address using Guest SSID
    MVP EXPERT
    Posted Apr 26, 2017 02:58 AM
    What is providing the DHCP for the Guest VLAN? Do you have any more information on your set up and any other troubleshooting steps? Are  you seeing these apipa addresses on mobile devices only?
    It looks like OAW-4704-US is Alcatel-Lucent model? The ArubaOS code 6.2.1.3 is very old as well.
  • 3.  RE: Aruba Controller Users lost connectivity and not getting ip address using Guest SSID
    Posted Apr 26, 2017 04:38 AM
    Hi
    WLC configured as  DHCP server and providing ips to Guest VLAN.
    we have enabled logs for one user but nothing abnormal found.
    we are getting these apipa addresses on some user laptops and the issue is intermittent.
    Also having ample of ip space for this Guest VLAN.
  • 4.  RE: Aruba Controller Users lost connectivity and not getting ip address using Guest SSID
    Posted Apr 26, 2017 07:41 AM
    How long has this been going on?  How long has the guest network been operational?
  • 5.  RE: Aruba Controller Users lost connectivity and not getting ip address using Guest SSID
    Posted Apr 26, 2017 07:53 AM
    Hi CJoseph,
    This issue is intermittent and having from around 3 months.
  • 6.  RE: Aruba Controller Users lost connectivity and not getting ip address using Guest SSID
    Posted Apr 26, 2017 08:07 AM
    What is your lease time?
    What are the ACLs for the guest role?  (type "show rights <guest role>") on the commandline.
    If you need immediate help, you should open a TAC case in parallel..
  • 7.  RE: Aruba Controller Users lost connectivity and not getting ip address using Guest SSID
    Posted Apr 26, 2017 08:21 AM
    Please check below output.
    show rights guest
    Derived Role = 'guest'
    Up BW:No Limit Down BW:No Limit
    L2TP Pool = default-l2tp-pool
    PPTP Pool = default-pptp-pool
    Periodic reauthentication: Disabled
    ACL Number = 3/0
    Max Sessions = 65535
    access-list List
    Position Name Type Location
    1 http-acl session
    2 https-acl session
    3 dhcp-acl session
    4 icmp-acl session
    5 dns-acl session
    6 v6-http-acl session
    7 v6-https-acl session
    8 v6-dhcp-acl session
    9 v6-icmp-acl session
    10 v6-dns-acl session
    http-acl
    Priority Source Destination Service Action TimeRange Log Expired Queue TOS 8021P Blacklist Mirror DisScan ClassifyMedia IPv4/6
    1 any any svc-http permit Low 4
    https-acl
    1 any any svc-https permit Low 4
    dhcp-acl
    1 any any svc-dhcp permit Low 4
    icmp-acl
    1 any any svc-icmp permit Low 4
    dns-acl
    1 any any svc-dns permit Low 4
    v6-http-acl
    1 any any svc-http permit Low 6
    v6-https-acl
    1 any any svc-https permit Low 6
    v6-dhcp-acl
    1 any any svc-v6-dhcp permit Low 6
    v6-icmp-acl
    1 any any svc-v6-icmp permit Low 6
    v6-dns-acl
    1 any any svc-dns permit Low 6
    Expired Policies (due to time constraints) = 0
  • 8.  RE: Aruba Controller Users lost connectivity and not getting ip address using Guest SSID
    Posted Apr 30, 2017 10:04 PM
    1. Please check the output for the following command to see if there are available addresses in the DHCP Pool
    show  ip dhcp statistics
    if there are no free addresses, you can probably  reduce the least time for the guest users or increase the size of the guest subnet & reconfigure DHCP pool accordingly (make sure if subnet change is done, it should be done across all the l3 interfaces which have IP on the guest subnet).
    2. If there are free addresses & client sitll gets an APIPA address, get the following outputs while the client is stuck in getting an IP address:
    config# logging level debugging network process dhcpd subcat all
    # show station-table | include <mac-address of user>
    # show log network all | include <nac-address of client>
  • 9.  RE: Aruba Controller Users lost connectivity and not getting ip address using Guest SSID
    Posted May 05, 2017 02:59 AM
    HI,
    There are many free ip addresses in Guest and as i mentioned before the issue is intermittent.
    logging is already enabled and i will share the logs once the issue is occured.
    Thanks for  the support.
  • 10.  RE: Aruba Controller Users lost connectivity and not getting ip address using Guest SSID
    Posted May 05, 2017 03:49 AM
    Do you have "Drop Broadcast and Known Multicast" enabled on that Virtual AP, and all of your Virtual APs?
