Aruba controller VPN Concentrator
  • 1.  Aruba controller VPN Concentrator
    Posted Mar 27, 2015 08:08 AM
    Hi guys, can a single controller handle IAP-VPN concentrator and normal AP termination & configuration together?
    What I heard is we do require second controller to handle the AP if the first unit is handling IAP-VPN concentrator.
    We are going to deploy 300 IAP, build VPN tunnel to controller while the controller is handling 50 units remote AP. Can it be done?
  • 2.  RE: Aruba controller VPN Concentrator
    Posted Mar 27, 2015 08:10 AM
    Yes, you just need to check platform and scaling numbers (users and tunnels)
  • 3.  RE: Aruba controller VPN Concentrator
    Posted Mar 27, 2015 08:13 AM
    The controller is 7220.
    Can you advise does it make any degrade of the performance in this scenario?
    We soon to have 300 IAP-VPN and 50 remote AP deployed.
    Thanks.
  • 4.  RE: Aruba controller VPN Concentrator
    Posted Mar 27, 2015 08:16 AM
    There should be no performance impact.
    A 7220 can handle up to 24k IPSec tunnels (each RAP and each IAP-VPN tunnel)
  • 5.  RE: Aruba controller VPN Concentrator
    Posted Mar 27, 2015 08:20 AM
    ok, got it.
    Thanks bro.
