Aruba Controller with LDAP server authentication failed
This thread has been viewed 22 times
  • 1.  Aruba Controller with LDAP server authentication failed
    Posted Oct 02, 2020 04:19 AM
    Hi, im trying to integrate 7010 controller with LDAP server on an AD. This will be a captive portal authentication. This is the configuration and status:
    (WLC-IDM) *[mynode] #show aaa authentication-server ldap LDAP-server
    LDAP Server "LDAP-server"
    Parameter                                Value
    Host                                     10.0.1.159
    Admin-DN                                 CN=wifi
    Admin-Passwd                             ********
    Allow Clear-Text                         Enabled
    Auth Port                                389
    Base-DN                                  DC=i*****ret,DC=group
    Filter                                   (objectclass=*)
    Key Attribute                            sAMAccountName
    Timeout                                  20 sec
    Mode                                     Enabled
    Preferred Connection Type                clear-text
    maximum number of non-admin connections  4
    Chase-Referrals                          Enabled
    (WLC-IDM) *[mynode] #show aaa authentication-server ldap LDAP-server status
    LDAP Server Table
    LDAP Server Attribute        Value
    Priority                     2
    Name                         LDAP-server
    Hostname                     10.0.1.159
    AuthPort                     389
    AuthSSLPort                  636
    Retries                      3
    Timeout                      20
    AdminDN                      CN=wifi
    AdminPasswd                  *****
    BaseDN                       DC=i*****ret,DC=group
    KeyAttribute                 sAMAccountName
    Allow Cleartext              yes
    Status                       Enabled
    InService                    Up
    InitDone                     yes
    AdminBound                   no
    Connection Type              clear text
    Server Down                  no
    Marked For Delete            no
    In Use Callback Set          no
    Outstanding Authentications  27
    RebindTimerSet               no
    RebindCount                  2
    ReqViolationCount            0
    I logged the security authmgr, did the query-user command and found this:
    Oct 2 14:04:59 :199802:  <3517> <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:922: LDAP Server LDAP-server: Error in Binding Admin to server: Timeout or Network error
    Oct 2 14:04:59 :199802:  <4127> <ERRS> |dot1x-proc:2|  ldapclient.c, ldap_client_bind_admin_cb:922: LDAP Server LDAP-server: Error in Binding Admin to server: Timeout or Network error
    Oct 2 14:05:01 :199802:  <4117> <ERRS> |dot1x-proc:1|  ldapclient.c, ldap_client_bind_admin_cb:972: LDAP Server LDAP-server: Error in Binding Admin to server: Probably error in credentials
    Oct 2 14:05:01 :199802:  <4127> <ERRS> |dot1x-proc:2|  ldapclient.c, ldap_client_bind_admin_cb:972: LDAP Server LDAP-server: Error in Binding Admin to server: Probably error in credentials
    Oct 2 14:05:59 :199802:  <3517> <ERRS> |authmgr|  ldapclient.c, ldap_client_bind_admin_cb:972: LDAP Server LDAP-server: Error in Binding Admin to server: Probably error in credentials
    Oct 2 14:08:49 :199802:  <3517> <ERRS> |authmgr|  ldapclient.c, ldap_auth_api:144: LDAP Server LDAP-server: User operation attempted when server is OOS
    Oct 2 14:08:54 :199802:  <3517> <ERRS> |authmgr|  ldapclient.c, ldap_auth_api:144: LDAP Server LDAP-server: User operation attempted when server is OOS
    What is the solution to this?
    Thank you.
  • 2.  RE: Aruba Controller with LDAP server authentication failed
    Posted Oct 02, 2020 06:24 AM
    It looks like your LDAP server is not even answering:
    I would go on the commandline of that LDAP server and do a "netstat -an" to make sure it is listening on port 389.
    Also, I would use an ldap browser like Softerra LDAP browser to connect to that server and ensure that your parameters are correct.
  • 3.  RE: Aruba Controller with LDAP server authentication failed
    Posted Oct 02, 2020 07:15 AM
    Thank you, i will ask the customer to do that.
     and the status said:
    AdminBound                   no
    Does this mean the Admin-DN and admin password could probably be incorrect?
  • 4.  RE: Aruba Controller with LDAP server authentication failed
    Posted Oct 02, 2020 07:33 AM
    Possibly.  The ldap browser would easily determine that.
  • 5.  RE: Aruba Controller with LDAP server authentication failed
    Posted Oct 05, 2020 11:00 PM
    So i used the LDAP browser and input the correct admin-dn. The status became like this:
    LDAP Server Table
    Priority                     2
    Name                         LDAP-server
    Hostname                     10.0.1.159
    AuthPort                     389
    AuthSSLPort                  636
    Retries                      3
    Timeout                      20
    AdminDN                      CN=wifi .,OU=WIFI,DC=i*****ret,DC=group
    AdminPasswd                  *****
    Allow Cleartext              yes
    Status                       Enabled
    InService                    Up
    InitDone                     yes
    AdminBound                   yes
    Server Down                  no
    Outstanding Authentications  0
    RebindTimerSet               no
    RebindCount                  0
    ReqViolationCount            0
    Note that the adminbound is now "yes".
    I tried to do the user query again, it now shows "timeout" instead of the "authentication failed" from before. I checked the log and this is what i got:
    Oct 6 09:40:19 :124004:  <3517> <DBUG> |authmgr|  aal_query_user_oneshot (1572)(INC) : os_auths 1, s LDAP-server type 3 inservice 1 markedD 0 sg_name
    Oct 6 09:40:19 :124004:  <3517> <DBUG> |authmgr|  aal_query_user_oneshot (1573)(INC) : os_reqs 1, s LDAP-server type 3 inservice 1 markedD 0
    Oct 6 09:40:39 :124004:  <3517> <DBUG> |authmgr|  server_cbh (163)(DEC) : os_reqs 0, s LDAP-server type 3 inservice 0 markedD 0
    Oct 6 09:40:39 :124607:  <3517> <DBUG> |authmgr|  server_cbh(): response=2 from Auth server 'LDAP-server for client:0 proto:7 eap-type:0'.
    Oct 6 09:40:39 :124004:  <3517> <DBUG> |authmgr|  server_cbh (422)(DEC) : os_auths 0, s LDAP-server type 3 inservice 0 markedD 0 sg_name
    Oct 6 09:40:39 :124004:  <3517> <DBUG> |authmgr|  Select server for method=, user=wifi, essid=<>, server-group=, last_srv LDAP-server
    Oct 6 09:40:39 :199802:  <3517> <ERRS> |authmgr|  server_group.c, ncfg_server_getnext:380: Unknown or empty server group "" (method=, user=wifi)
    Oct 6 09:40:39 :109000:  <3517> <DBUG> |authmgr|  LDAP Server LDAP-server: Server down callback.
    Oct 6 09:40:39 :109013:  <3517> <WARN> |authmgr|  LDAP Server LDAP-server: Connectivity lost to the Server, trying to re-establish
    Oct 6 09:40:39 :124004:  <3517> <DBUG> |authmgr|  LDAP: ldap_client_server_down_cb/1254 setting server LDAP-server out of service
    Oct 6 09:40:39 :109017:  <3517> <INFO> |authmgr|  LDAP Server LDAP-server: Setting Server Out of Service
    Oct 6 09:40:39 :124004:  <3517> <DBUG> |authmgr|  LDAP unbind: ldap_client_set_out_of_service
    Oct 6 09:40:39 :109018:  <3517> <INFO> |authmgr|  LDAP Server LDAP-server: Unbinding Admin Context from the server
    Oct 6 09:40:39 :109019:  <3517> <INFO> |authmgr|  LDAP Server LDAP-server: Unbinding User Context from the server
    Oct 6 09:40:39 :109015:  <3517> <INFO> |authmgr|  LDAP Server LDAP-server: Starting Timer to rebind to server in 1500 ms
    Oct 6 09:40:39 :109000:  <3517> <DBUG> |authmgr|  LDAP Server LDAP-server: Timer handler to bind to server
    Oct 6 09:40:39 :109000:  <3517> <DBUG> |authmgr|  LDAP Server LDAP-server: initializing LDAP structure for host:10.0.1.159 sslport:636
    Oct 6 09:40:39 :109000:  <3517> <DBUG> |authmgr|  LDAP Server LDAP-server: Initializing TLS Options
    Oct 6 09:40:39 :109000:  <3517> <DBUG> |authmgr|  LDAP Server LDAP-server: preferred connection type 3
    Oct 6 09:40:39 :109005:  <3517> <INFO> |authmgr|  LDAP Server LDAP-server: Admin - Using Clear Text Connection
    Oct 6 09:40:39 :109000:  <3517> <DBUG> |authmgr|  LDAP Server LDAP-server: Setting ASYNC callback option
    Oct 6 09:40:39 :109000:  <3517> <DBUG> |authmgr|  LDAP Server LDAP-server: Setting timeout to 20 seconds
    Oct 6 09:40:39 :109000:  <3517> <DBUG> |authmgr|  LDAP Server LDAP-server: Initialization completed succssfully
    Oct 6 09:40:39 :109000:  <3517> <DBUG> |authmgr|  LDAP Server LDAP-server: Setting server-down callback
    Oct 6 09:40:39 :109001:  <3517> <DBUG> |authmgr|  LDAP Server LDAP-server: Initialization completed successfully
    Oct 6 09:40:39 :109011:  <3517> <INFO> |authmgr|  LDAP Server LDAP-server: Binding Admin to server
    Oct 6 09:40:39 :109000:  <3517> <DBUG> |authmgr|  LDAP Server LDAP-server: Sent Bind request to server
    Oct 6 09:40:39 :109015:  <3517> <INFO> |authmgr|  LDAP Server LDAP-server: Starting Timer to rebind to server in 60000 ms
    Oct 6 09:40:40 :124004:  <3517> <DBUG> |authmgr|  Auth GSM: Num dev_id_cache entries aged = 0
    Do you know what is the problem now?
    Thank you.
  • 6.  RE: Aruba Controller with LDAP server authentication failed
    MVP EXPERT
    Posted Oct 06, 2020 04:25 AM
    The Server Timeout suggests that there is a configuration issues between the LDAP server and the Controllers. The controller will mark the auth server Out of Service if there is no response.
    Does the controller still have reachability to the LDAP Server? Is there any logs you can check the LDAP server as to why the auth requests are being ignored? If you need to bring the AAA Server back into service to avoid waiting for the timeout, use the command below:
    (Aruba7030) *[mynode] #aaa inservice [ServerGroup] [AuthServer]
  • 7.  RE: Aruba Controller with LDAP server authentication failed
    Posted Oct 06, 2020 05:59 AM
    Yes, the controller can reach the LDAP-server.
    The AD team said that there are no logs available from the controller.
    I did the commands stated, it still shows 'request timeout'
