Aruba Controlller SSID WLAN configuration
  • 1.  Aruba Controlller SSID WLAN configuration
    Posted Aug 19, 2019 09:24 PM
    Hi All
    May I know can 1 SSID can configure more than 2 VLAN configuration.
  • 2.  RE: Aruba Controlller SSID WLAN configuration
    Posted Aug 19, 2019 09:39 PM
    Yes.
    How would you be defining the user vlan, in that case?
  • 3.  RE: Aruba Controlller SSID WLAN configuration
    Posted Aug 19, 2019 10:07 PM
    Hi
    That a question I keep thinking.
    My customer enviroment is a school campus, which got Elementary school, Middle School and High School.  the best pratice way is each School have their own WLAN. but if we merge all the campus to 1 SSID with multiple VLAN can we do it that way?
  • 4.  RE: Aruba Controlller SSID WLAN configuration
    Posted Aug 19, 2019 10:08 PM
    If they use different usernames and passwords, they vlan can be keyed based on the group membership in the directory, yes.
  • 5.  RE: Aruba Controlller SSID WLAN configuration
    Posted Aug 19, 2019 10:32 PM
    Hi ,
    Means create the user database at the controller and assigin them to the right group?
  • 6.  RE: Aruba Controlller SSID WLAN configuration
    Posted Aug 20, 2019 03:32 AM
    I meant if the users are in active directory.  You want to avoid creating users on WLAN controllers.
