Wired Intelligent Edge
aruba cx 6000 switch ip helper-address
  • 1.  aruba cx 6000 switch ip helper-address
    Posted May 18, 2023 05:09 PM
     ip helper-address command did not appear in int vlan ***
    6000(config)# int vlan 10
    6000(config-if-vlan)# ip helper-address ***.***.4.2
    Invalid input: helper-address
  • 2.  RE: aruba cx 6000 switch ip helper-address
    Posted May 18, 2023 06:38 PM
    Do you have firmware10.10.x on the 6000s?
  • 3.  RE: aruba cx 6000 switch ip helper-address
    Posted May 19, 2023 01:49 AM
    no its 10.8
  • 4.  RE: aruba cx 6000 switch ip helper-address
    Posted May 19, 2023 02:38 AM
    ok then upgrade to that version also note that 10.08 is end of support
  • 5.  RE: aruba cx 6000 switch ip helper-address
    Posted May 25, 2023 11:53 AM
    For those with the same problem, you can use the Aruba Switch Feature Navigator, and then when you search under L3 features for DHCP relay, you will find that that feature was introduced in 10.02.0002. The point that 10.08 is end of support is a separate point, relevant for other reasons as you probably want to run supported software version.
