Dear Community,
we are currently using CX-6100 / Aruba-2530 devices with Mac-Based ClearPass.
CoA is working properly.
While connecting devices like Computer,Laptop,Printer,CCTV,.. devices showing up in AccessTracker.
The issue is while connecting old devices like Serial-Ethernet Converter, Epson recipient printer, ... devices are not showing in the AccessTracker.
I recently captured the uplink port with wireshark between the swtiches and clearpass. While connecting devices you can see radius packages requesting at clearpass.
While old devices are not requesting radius packages.
Same problem on both switch types. Heres an example config from one switch:
Current configuration:
!Version ArubaOS-CX PL.10.10.0002
!export-password: default
radius-server host SECRET key ciphertext SECRET
aaa group server radius cppm
server SECRET
aaa accounting port-access start-stop interim
radius dyn-authorization enable
radius dyn-authorization client SECRET secret-key SECRET
aaa authentication port-access mac-auth
radius server-group cppm
enable
interface 1/1/3
no shutdown
vlan access 1
enable
Thanks until yet.
Best regards
