SD- Branch
Aruba CX-6200 and A9004 Gateway using UBT
This thread has been viewed 50 times
  • 1.  Aruba CX-6200 and A9004 Gateway using UBT
    Posted Oct 15, 2021 09:46 AM
    Hi everyone,
    I am testing UBT in my lab, more accurately sending the gateway role from CPPM to my A9004.
    After configuring the paramenters according to the great tutorial of Airheads Brodcasting Channel my switch keeps on registering state
    ArubaCX-6200# sh ubt state
    Zone Aruba_Zone:
    Local Master Server (LMS) State:
    LMS Type IP Address State Role
    Primary : 192.168.11.1 ready_for_bootstrap operational_primary
    Switch Anchor Controller (SAC) State:
    IP Address MAC Address State
    Active : 192.168.11.1 registering
    Checking the deb buf using the command "show debug buffer module ubt reverse" I can see that the switch is expecting for something from the gateway and I wonder if it is necessary configuring anything on te gateway beyond that the role sent from CPPM exists.
    ArubaCX-6200# sh deb buf module ubt reverse
    show debug buffer
    2021-10-15:12:10:21.868261|tunnelednode|LOG_ERR|MSTR|1|UBT|UBT_PACKET|papi_RecvMsg: Unable to calculate MD5 checksum - Cluster Idx is not valid
    2021-10-15:12:10:21.865753|tunnelednode|LOG_INFO|MSTR|1|UBT|UBT_PACKET|Zone: Aruba_Zone vrf: default Sending SAC Bootstrap to node: 192.168.11.1
    2021-10-15:12:10:21.865691|tunnelednode|LOG_INFO|MSTR|1|UBT|UBT_PACKET|Zone: Aruba_Zone vrf: default papi_SendMsg: iBufLen 72, iSocket 10
    2021-10-15:12:10:21.865673|tunnelednode|LOG_INFO|MSTR|1|UBT|UBT_CP|Multicast tunnel MTU size: 1566
    2021-10-15:12:10:21.865658|tunnelednode|LOG_INFO|MSTR|1|UBT|UBT_CP|rr MTU, IP address: 192.168.11.1, MTU: 1566
    2021-10-15:12:10:21.865625|tunnelednode|LOG_INFO|MSTR|1|UBT|UBT_PACKET|Zone: Aruba_Zone vrf: default sacMode 1
    2021-10-15:12:10:21.865608|tunnelednode|LOG_INFO|MSTR|1|UBT|UBT_CP|Zone: Aruba_Zone vrf: default SAC state: Bootstrapping, event: Timeout
    2021-10-15:12:10:21.865590|tunnelednode|LOG_INFO|MSTR|1|UBT|UBT_PACKET|Zone: Aruba_Zone vrf: default SAC BStrap to 192.168.11.1 (Active) initiated
    2021-10-15:12:10:21.865561|tunnelednode|LOG_WARN|MSTR|1|UBT|UBT_CP|Zone: Aruba_Zone vrf: default Timeout elapsed while in state 'Bootstrapping'for IP:192.168.11.1
    2021-10-15:12:10:18.864991|tunnelednode|LOG_ERR|MSTR|1|UBT|UBT_PACKET|papi_RecvMsg: Unable to calculate MD5 checksum - Cluster Idx is not valid
    2021-10-15:12:10:18.862310|tunnelednode|LOG_INFO|MSTR|1|UBT|UBT_PACKET|Zone: Aruba_Zone vrf: default Sending SAC Bootstrap to node: 192.168.11.1
    2021-10-15:12:10:18.862246|tunnelednode|LOG_INFO|MSTR|1|UBT|UBT_PACKET|Zone: Aruba_Zone vrf: default papi_SendMsg: iBufLen 72, iSocket 10
    2021-10-15:12:10:18.862228|tunnelednode|LOG_INFO|MSTR|1|UBT|UBT_CP|Multicast tunnel MTU size: 1566
    2021-10-15:12:10:18.862213|tunnelednode|LOG_INFO|MSTR|1|UBT|UBT_CP|rr MTU, IP address: 192.168.11.1, MTU: 1566
    2021-10-15:12:10:18.862181|tunnelednode|LOG_INFO|MSTR|1|UBT|UBT_PACKET|Zone: Aruba_Zone vrf: default sacMode 1
    2021-10-15:12:10:18.862165|tunnelednode|LOG_INFO|MSTR|1|UBT|UBT_CP|Zone: Aruba_Zone vrf: default SAC state: Bootstrapping, event: Timeout
    2021-10-15:12:10:18.862148|tunnelednode|LOG_INFO|MSTR|1|UBT|UBT_PACKET|Zone: Aruba_Zone vrf: default SAC BStrap to 192.168.11.1 (Active) initiated
    2021-10-15:12:10:18.862130|tunnelednode|LOG_INFO|MSTR|1|UBT|UBT_CP|ClusterIdx: 0 zone: Aruba_Zone other LMS IP is not configured
    2021-10-15:12:10:18.862103|tunnelednode|LOG_WARN|MSTR|1|UBT|UBT_CP|Zone: Aruba_Zone vrf: default Retry exceeded while in state 'Bootstrapping'for IP:192.168.11.1
    2021-10-15:12:10:14.878120|tunnelednode|LOG_ERR|MSTR|1|UBT|UBT_PACKET|papi_RecvMsg: Unable to calculate MD5 checksum - Cluster Idx is not valid
    2021-10-15:12:10:14.876495|tunnelednode|LOG_INFO|MSTR|1|UBT|UBT_PACKET|Zone: Aruba_Zone vrf: default Sending SAC Bootstrap to node: 192.168.11.1
    2021-10-15:12:10:14.876429|tunnelednode|LOG_INFO|MSTR|1|UBT|UBT_PACKET|Zone: Aruba_Zone vrf: default papi_SendMsg: iBufLen 72, iSocket 10
    2021-10-15:12:10:14.876411|tunnelednode|LOG_INFO|MSTR|1|UBT|UBT_CP|Multicast tunnel MTU size: 1566
    2021-10-15:12:10:14.876396|tunnelednode|LOG_INFO|MSTR|1|UBT|UBT_CP|rr MTU, IP address: 192.168.11.1, MTU: 1566
    2021-10-15:12:10:14.876363|tunnelednode|LOG_INFO|MSTR|1|UBT|UBT_PACKET|Zone: Aruba_Zone vrf: default sacMode 1
    2021-10-15:12:10:14.876345|tunnelednode|LOG_INFO|MSTR|1|UBT|UBT_CP|Zone: Aruba_Zone vrf: default SAC state: Bootstrapping, event: Timeout
    I must say that the A9004 and the CX6200 have direct connection.
    ArubaCX-6200# sh ip int brief
    Interface IP Address Interface Status
    link/admin
    vlan1 No Address down/up
    vlan11 192.168.11.3/24 up/up
    vlan21 192.168.21.3/24 up/up
    vlan31 192.168.31.3/24 up/up
    ArubaCX-6200# sh vlan
    VLAN Name Status Reason Type Interfaces
    1 DEFAULT_VLAN_1 down no_member_forwarding default 1/1/2-1/1/28
    11 Gestion up ok static 1/1/1
    21 Corp up ok static 1/1/1
    31 Gest up ok static 1/1/1
    4091 UBT down no_member_port static
    ArubaCX-6200# sh run int 1/1/1
    interface 1/1/1
    no shutdown
    description Link=>GW0/0/1
    vlan trunk native 1
    vlan trunk allowed 11,21,31
    exit
    ubt-client-vlan 4091
    ubt zone Aruba_Zone vrf default
    primary-controller ip 192.168.11.1
    enable
    ip source-interface ubt interface vlan11
    Do you guys have any advice or suggestion? Is there anything to configure in the gateway side?
    Thanck you very much in advanced!!
    JoseMi
    Jose Miguel Cruz
    Technical Presales Consultant
    Tech Data España, S.L.U.
  • 2.  RE: Aruba CX-6200 and A9004 Gateway using UBT
    Posted Oct 20, 2021 07:49 AM
    Do you have licenses (AP+PEF) on your 9004 gateway?
    Can you check the logs on the 9004 gateway? I would think those provide more information.
    What is the firmware version on the 9004 gateway?
    What is the firmware version on the switch?
    There is no specific configuration needed that I could think of, except that the gateway-role has to be present on the gateway, and the gateway has to be licensed.
  • 3.  RE: Aruba CX-6200 and A9004 Gateway using UBT
    Posted 14 days ago
    I have similar configuration except of controller(in my case VM cluster of controllers managed by Mobility Conductors).
    debug result is:
    2024-07-04:23:03:01.277666|tunnelednode|LOG_ERR|CDTR|1|UBT|UBT_PACKET|Zone: CPPM, VRF: default, Addition of Tunnel MTU TLV failed
    2024-07-04:23:03:01.277641|tunnelednode|LOG_ERR|CDTR|1|UBT|UBT_PACKET|Zone: CPPM VRF: default  Unable to get Multicast tunnel MTU size from RR table
    2024-07-04:23:02:56.272741|tunnelednode|LOG_ERR|CDTR|1|UBT|UBT_PACKET|Zone: CPPM, VRF: default, Addition of Tunnel MTU TLV failed
    2024-07-04:23:02:56.272716|tunnelednode|LOG_ERR|CDTR|1|UBT|UBT_PACKET|Zone: CPPM VRF: default  Unable to get Multicast tunnel MTU size from RR table
    I've tried to change MTU on both sides but problem still persist
    P.S.
    I'm new to Aruba
  • 4.  RE: Aruba CX-6200 and A9004 Gateway using UBT
    Posted 11 days ago
    You responded to an old post. If you are not familiar with Aruba products, it's probably best to work with your Aruba partner or Aruba TAC Support.
