Wired Intelligent Edge
Aruba CX 6300 10G SFP Compatability
This thread has been viewed 16 times
  • 1.  Aruba CX 6300 10G SFP Compatability
    Posted Feb 01, 2023 01:53 AM
    I am currenlty deploying a fleet of aruba cx 6300 switches.
    When i try to connect a 10G LMR SFP Module, it says incompatible interface. And from reading i have found out that LMR SFPs are not compatible and need aditional modules to be used with CX 6300.
    So, would you please recommend me what the additional products that i need to make this SFP work, or if there are any commands that i can run to make it compatible if there are any?.
  • 2.  RE: Aruba CX 6300 10G SFP Compatability
    Posted Feb 01, 2023 02:06 AM
    There are only two 6300 switch that supports LRM transceivers and thats R8S90A and R8S92A
  • 3.  RE: Aruba CX 6300 10G SFP Compatability
    Posted Feb 01, 2023 02:39 AM
    Thank you,
    is there additional module that i can buy to make it work?
  • 4.  RE: Aruba CX 6300 10G SFP Compatability
    Posted Feb 01, 2023 03:52 AM
    Aruba does not provide any module.
    You can search the Internet for Media Converters
    Here is  the option that could work
    https://www.perle.com/products/media-converters/10-gigabit-standalone-rate-converter.shtml
  • 5.  RE: Aruba CX 6300 10G SFP Compatability
    Posted Feb 01, 2023 09:33 AM
    Your solution here is either be to use media converters as @ariyap suggested, (which you should avoid--using media converters in context like this should be a last resort)) or, if your runs are short enough, use J9150A/D/E 10GBase-SR SFPs, or, if your runs are too long, to pull single mode fiber and use J9151A/D/E SFPs.  No switch commands are going to help you here, the problem is that the switches lack the hardware to drive LRM optics.
