Wired Intelligent Edge
Aruba CX 6300 VSF via 10G optic SFP up to 18KM
This thread has been viewed 59 times
  • 1.  Aruba CX 6300 VSF via 10G optic SFP up to 18KM
    Posted Feb 09, 2024 10:53 AM
    I have a problem to create a VSF chain setup between switches which are located in separate DC.
    Between DC is active optical fiber.
    Port 28 is on the Conductor site and port 27 on Standby site.
    Please could you provide any suggestion how to proceed?
  • 2.  RE: Aruba CX 6300 VSF via 10G optic SFP up to 18KM
    Posted Feb 10, 2024 12:42 AM
    there are no supported transceivers for 6300 switches for 18Km.
    Generally you can use single mode transceivers for upto 10Km but even if the DCs where within 10Km if each other I would not use it for VSF stacking between two DC over that distance.
  • 3.  RE: Aruba CX 6300 VSF via 10G optic SFP up to 18KM
    Posted Feb 10, 2024 10:03 AM
    I know that only 10Km transceiver is supported but it is in the case when is using dark fiber, but in my case between DCs is L2 active optical transport (DWDM) used and I dont see any reason why VSF could not to be used.
  • 4.  RE: Aruba CX 6300 VSF via 10G optic SFP up to 18KM
    Posted Feb 12, 2024 04:50 AM
    Hi! I add a question to what was already written by @ariyap, can you explain us what is the real eason behind your idea of deploying a VSF stack between two "so far" Datacenters if the only available interconnecting link is a single fibre optic connection (thus the VSF nodes will just connect each others - with no VSF interlink resiliency/redundancy - and absolutely nothing more)?
  • 5.  RE: Aruba CX 6300 VSF via 10G optic SFP up to 18KM
    Posted Feb 12, 2024 05:27 AM
    the reason is to increase fiber throughput on the interconnected DC's link up to speed 10Gig.
  • 6.  RE: Aruba CX 6300 VSF via 10G optic SFP up to 18KM
    Posted Feb 13, 2024 08:44 AM
    What is the «problem» and please elaborate on "active optical fiber"
    Steinar
  • 7.  RE: Aruba CX 6300 VSF via 10G optic SFP up to 18KM
    Posted Feb 13, 2024 11:39 AM
    between DCs is third party L2 transport = DWDM optical Transponder.
    To established of VSF I used command 'vsf start-auto-stacking'.
    the configuration on the Conductor is:
    ssh server vrf default
    ssh server vrf mgmt
    vsf secondary-member 2
    vsf member 1
        type jl664a
        link 1 1/1/26
        link 2 1/1/25
    vsf member 2
        type jl664a
        link 1 2/1/25
        link 2 2/1/26
    After few time rebooting of standbys switch I got vsf status:
    6300# sh vsf detail
    VSF Stack
            MAC Address                  : 38:0:0:5:1:c0
            Secondary                    : 2
            Topology                     : chain
            Status                       : Active Fragment
            Split Detection Method       : None
            Software Version             : FL.10.11.1030
            Force Autojoin               : Disabled
            Autojoin Eligibility Status  : Not Eligible
            Autojoin Ineligibility Reason: Configuration changes detected
            Contact                      :
    Member ID                            : 1
            Type                         : JL664A
            Model                        : 6300M 24-port 1GbE and 4-port SFP56 Switch
            Status                       : Conductor
            ROM Version                  : FL.01.12.0002
            Serial Number                : SGxxxxxxx5T
            Uptime                       : 2 hours, 17 minutes
            CPU Utilization              : 32%
            Memory Utilization           : 24%
            VSF Link 1                   : Up, connected to peer member 2, link 1
            VSF Link 2                   : Down
    Member ID                            : 2
            MAC Address                  : 38:0:0:5:e:80
            Type                         : JL664A
            Model                        :
            Status                       : Standby Booting
            ROM Version                  :
            Serial Number                :
            Uptime                       :
            CPU Utilization              : 0%
            VSF Link 1                   : Up, connected to peer member 1, link 1
            VSF Link 2                   : Down
    6300#
    6300# sh vsf link detail
    VSF Member: 1  Link 1
    Port     State                 Status Code  Peer Interface  Peer System MAC    Peer Product Type
    1/1/26   up                    S            2/1/25          38:0:0:5:e:80          JL664A
    VSF Member: 1  Link 2
    1/1/25   down                  D
    VSF Member: 2  Link 1
    2/1/25   down                  D
    VSF Member: 2  Link 2
    2/1/26   down                  D
    Status Code abbreviation:
    S   - Success      D - Interface physically down     T   - Peer timed out
    recovery-2# show vsf diagnostics
    This Mbr ID              : 2
    Mbr Mac Address         type           Status
    ID
    2   38:0:0:5:e:80   JL664A         Unknown
     VSF Member 2
         Link       Peer    Peer
    Link State      Member  Link   Interfaces
    1    up         0       0      2/1/25
    2    down       0       0      2/1/26
    2/1/25   up                    S            1/1/26          38:0:0:5:1:c0          JL664A
    2/1/26   down                  D
    and after few minutes the topology had been changed to STANADALONE and status NOT PRESENT but still the link is UP
    6300# sh vsf detail
    VSF Stack
            Secondary                    : 2
            Topology                     : standalone
            Contact                      :
    Member ID                            : 1
            Type                         : JL664A
            Status                       : Conductor
            Uptime                       : 2 hours, 25 minutes
            CPU Utilization              : 3%
            VSF Link 1                   : Down
            VSF Link 2                   : Down
    Member ID                            : 2
            MAC Address                  :
            Type                         : JL664A
            Model                        :
            Status                       : Not Present
            ROM Version                  :
            Serial Number                :
            Uptime                       :
            VSF Link 1                   : Down
            VSF Link 2                   : Down
    6300#
    1/1/25   down                  D
    2/1/25   down                  D
    2/1/26   down                  D
  • 8.  RE: Aruba CX 6300 VSF via 10G optic SFP up to 18KM
    Posted Feb 13, 2024 01:54 PM
    There are two options here:
    Option #1: On the secondary switch run the command: vsf force-auto-join then vsf start-auto-stacking
    Option #2: Reset the secondary switch to factory default setting and reboot the switch with the stacking fiber connected.
  • 9.  RE: Aruba CX 6300 VSF via 10G optic SFP up to 18KM
    Posted Feb 14, 2024 04:43 AM
    Edited by Steinar Grande Feb 14, 2024 04:52 AM
    The issue is with your : "third party L2 transport = DWDM optical Transponder"
    Clarify the interoperability options in use. it must be : non invasive,
    meaning:
    not interfere anything on the last experience at the transceiver end's, or anywhere else !
    and make sure your fiber color (nm) is correct as agreed on with your. third party L2 transport
    Follow the best practice and do the stacking manual; switch by switch locally at one site; and it will work.
    (before deploying DC to DC's)
    Regarding the distance and tranceiver, the Datasheet: state:
    "Flexibility to create stacks that span longer distances such as hundreds of meters across campuses
    to kilometres between sites using long-range 10GbE/25GbE transceivers"
    Happy stacking
    Steinar
    Attachment(s)
    pdf
    VSF best practice.pdf   558 KB 1 version
    pdf
    vsf.pdf   723 KB 1 version
  • 10.  RE: Aruba CX 6300 VSF via 10G optic SFP up to 18KM
    Posted Feb 15, 2024 07:17 AM
    on my desk the switches side by side worked perfectly but after distribution to the DCs dont, if the optical transport is included.
    definitely the third party have to check if the optical transport is transparent without any insertions to the interconnection.
    I will see what the COLT's verdict will be. I will update
