Aruba CX 6300F with Clearpass DUR Client shows unauthenticated
This thread has been viewed 100 times
  • 1.  Aruba CX 6300F with Clearpass DUR Client shows unauthenticated
    Posted Feb 09, 2021 07:47 AM
    Hello communitiy,
    we have an Aruba CX 6300f switch and a Clearpass running.
    We have configured downloadable user roles on the switch and the Clearpass.
    after a successful authentication via 802.1x the client shows the status unauthenticated. However, it gets an IP and can access resources on the same network.
    The switch displays the status authenticatied.
    I think the error is in the acl that is downloaded on the switch.
    the ACL see picture.
    Many thanks
  • 2.  RE: Aruba CX 6300F with Clearpass DUR Client shows unauthenticated
    MVP GURU
    Posted Feb 09, 2021 03:39 PM
    What do you have on CLI with command about user role ?
    ACEP / ACMX #107 / ACDX #1281
  • 3.  RE: Aruba CX 6300F with Clearpass DUR Client shows unauthenticated
    Posted Feb 10, 2021 09:58 AM
    Hi Leon,
    when you say the client says unauthenticated, do you mean that Windows shows that on the adapter setting? I would say that is a problem with Windows then, if everything else is working as expected.
    What does the switch say when you look into the user with "show port-access client detail"?
    AutoCreation
  • 4.  RE: Aruba CX 6300F with Clearpass DUR Client shows unauthenticated
    Posted Feb 10, 2021 10:16 AM
    yes windows shows unauthenticated on the network adapter...
    when I change the Acl Seq 100 alltraffic from drop to permit, everything works fine.
    the switch shows authenticated on both
    thanks
  • 5.  RE: Aruba CX 6300F with Clearpass DUR Client shows unauthenticated
    MVP GURU
    Posted Feb 10, 2021 02:39 PM
    the output of command ask by bkohnhe ( show port-access client detail)
  • 6.  RE: Aruba CX 6300F with Clearpass DUR Client shows unauthenticated
    Posted Feb 11, 2021 03:17 AM
    here is the switch output for the rule with the dorp at the ende:
    show port-access clients detail
    Port Access Client Status Details:
    Client e8:9a:8f:27:91:33, SYSTEC\vertrieb-test
    Session Details
    Port : 1/1/1
    Session Time : 51s
    IPv4 Address :
    IPv6 Address :
    VLAN Details
    VLAN Group Name :
    VLANs Assigned : 26,30
    Access : 30
    Native Untagged : 30
    Allowed Trunk : 26
    Authentication Details
    Status : dot1x Authenticated
    Auth Precedence : dot1x - Authenticated, mac-auth - Not attempted
    Authorization Details
    Role : TG_Aruba_CX_DUR_Vertrieb_restricted-3083-3
    Status : Applied
    Role Information:
    Type : clearpass
    Status: Completed
    Reauthentication Period :
    Cached Reauthentication Period :
    Authentication Mode :
    Session Timeout :
    Client Inactivity Timeout :
    Description :
    Gateway Zone :
    UBT Gateway Role :
    UBT Gateway Clearpass Role :
    Access VLAN :
    Native VLAN : 30
    Allowed Trunk VLANs : 26
    Access VLAN Name :
    Native VLAN Name :
    Allowed Trunk VLAN Names :
    VLAN Group Name :
    MTU :
    QOS Trust Mode :
    STP Administrative Edge Port :
    PoE Priority :
    Captive Portal Profile :
    Policy : DUR-Vertrieb_TG_Aruba_CX_DUR_Vertrieb_restricted-3083-3
    Access Policy Details:
    Policy Name : DUR-Vertrieb_TG_Aruba_CX_DUR_Vertrieb_restricted-3083-3
    Policy Type : Downloaded
    Policy Status : Applied
    SEQUENCE CLASS TYPE ACTION
    10 DHCP-DNS_TG_Aruba_CX_DUR_... ipv4 permit
    30 VLAN25_TG_Aruba_CX_DUR_Ve... ipv4 drop
    40 VLAN29_TG_Aruba_CX_DUR_Ve... ipv4 drop
    100 alltraffic_TG_Aruba_CX_DU... ipv4 drop
    Class Details:
    class ip DHCP-DNS_TG_Aruba_CX_DUR_Vertrieb_restricted-3083-3
    10 match udp any eq 67 any
    20 match udp any eq 68 any
    30 match udp any eq 53 any
    class ip VLAN25_TG_Aruba_CX_DUR_Vertrieb_restricted-3083-3
    10 match any any 192.168.25.0/255.255.255.0 count
    class ip VLAN29_TG_Aruba_CX_DUR_Vertrieb_restricted-3083-3
    10 match any any 192.168.29.0/255.255.255.0
    class ip alltraffic_TG_Aruba_CX_DUR_Vertrieb_restricted-3083-3
    20 match any any any
    Tobias Gabriel
  • 7.  RE: Aruba CX 6300F with Clearpass DUR Client shows unauthenticated
    Posted Feb 11, 2021 05:46 AM
    That is strange.
    I just tested it in my setup. I built an ACL with only DNS and DHCP allowed and everything else denied, just like you.
    Windows shows it is authenticated but the network is not identified, as expected, because I don't have a DHCP in my test environment.
    The switch looks the same like yours. Does every Windows client show unauthenticated?
    AutoCreation
  • 8.  RE: Aruba CX 6300F with Clearpass DUR Client shows unauthenticated
    Posted Feb 12, 2021 03:17 AM
    at the moment I´m working from home and I can only test with one Client with reomte connection.
    Next week I am back at office and I will test the authentication with an other client.
    Maybe you are right and this is only a client problem.
  • 9.  RE: Aruba CX 6300F with Clearpass DUR Client shows unauthenticated
    Posted Feb 15, 2021 08:37 PM
    Leon,
    I feel like you need to adjust your DHCP and DNS entries. Here is what I am using. DHCP will use a source port of 68 and dest port of 67 from the server. Same with DNS it is a destination port not a source port.
    class ip DHCP
    10 match udp any eq 68 any eq 67 count
    exit
    class ip DNS
    10 match udp any any eq 53 count
    exit
    With your other rules your not permitting any traffic.
    Class Details:
    Christopher Calhoun
  • 10.  RE: Aruba CX 6300F with Clearpass DUR Client shows unauthenticated
    Posted Feb 16, 2021 03:19 AM
    Hi Christopher,
    you made my day.
    That was the soloution for my problem.
    Now everything is working with the restricted rule...
    Thank you for your support Christopher.
    Tobias Gabriel
  • 11.  RE: Aruba CX 6300F with Clearpass DUR Client shows unauthenticated
    Posted Feb 16, 2021 07:22 AM
    You are welcome I noticed in the Wired Enforcement Policy Guide that there are some references to this that are incorrect. Ask me how I know? :) I typed them in and had weird issues. I sent a note to cappalli hopefully they can edit that.
    -CC
    Christopher Calhoun
  • 12.  RE: Aruba CX 6300F with Clearpass DUR Client shows unauthenticated
    MVP GURU
    Posted Feb 16, 2021 03:53 PM
    ccappali don't work for Aruba... but there is a new author of the doc (search on Airheads !)
  • 13.  RE: Aruba CX 6300F with Clearpass DUR Client shows unauthenticated
    Posted Feb 16, 2021 03:58 PM
    Non the less have whomever wrote it update it. It is wrong.
    This post led me to believe cappalli wrote it.
    Christopher Calhoun
  • 14.  RE: Aruba CX 6300F with Clearpass DUR Client shows unauthenticated
    MVP GURU
    Posted Feb 17, 2021 09:44 AM
    there is a new release with support of CX https://support.hpe.com/hpesc/public/docDisplay?docId=a00091135en_us (look the changelog)
  • 15.  RE: Aruba CX 6300F with Clearpass DUR Client shows unauthenticated
    Posted Feb 17, 2021 09:59 AM
    That is the document I am referencing that is wrong. For example on Page 179. The DHCP and DNS class match are incorrect.
    Same on 166
    Christopher Calhoun
