Wired Intelligent Edge
Aruba CX and USB-C Console Drivers
  • 1.  Aruba CX and USB-C Console Drivers
    Posted Feb 25, 2023 09:33 PM
    I have a need to access my Aruba CX 6200/6300 switches via console for OOBM from an Ubuntu server machine.  I have found very little information about drivers for the USB-C console access on CX switches for Linux.
    The vendor and device ID information for the USB-C console on CX 6200/6300 is:
    03f0:013f HP, Inc HPN Serial Port
    Can anyone point me in the right direction for where to obtain the drivers?
    I would also be interested in MacOS drivers as I'm sure it will come in handy in the future.
    Thank you.
  • 2.  RE: Aruba CX and USB-C Console Drivers
    Posted Feb 26, 2023 05:19 AM
    All USB console drivers are available from asp.arubanetworks.com. Just search for USB.
    Best, Gorazd
    Gorazd Kikelj
    MVP Expert 2023
  • 3.  RE: Aruba CX and USB-C Console Drivers
    Posted Feb 26, 2023 04:37 PM
  • 4.  RE: Aruba CX and USB-C Console Drivers
    Posted Feb 27, 2023 07:39 AM
    On my Ubuntu 22.04 with kernel 5.19, the CX serial port of my 6300F is detected without any issues or additional drivers, and from 'dmesg' I can see it got assigned /dev/ttyACM0.
    When I use 'screen' to connect, I have access to the console port:
    % sudo screen /dev/ttyACM0 115200
    <enter>
    CX6300F login:
  • 5.  RE: Aruba CX and USB-C Console Drivers
    Posted Feb 28, 2023 09:33 PM
    Hi Herman,
    Thank you.  I was able to find /dev/ttyACM0 without the installation of additional drivers.
    Worked perfectly with both screen and picocom.
    Thank you.
