Wired Intelligent Edge
Aruba CX OVA on GNS3
This thread has been viewed 96 times
  • 1.  Aruba CX OVA on GNS3
    Posted Jun 22, 2020 01:21 PM
    Hi all,
    Need some help here releted to CX OVA on GNS3.
    Problem I'm facing is when I start the CX OVA template on GNS3 my machine gets restart automatically.
    I have windows 10 virtual machine hosted on VMware esxi 6.7
    GNS3 is installed on this machine
    Oracle virtual box
    CX OVA is imported using oracle virtual box.
    Can someone help me on this
  • 2.  RE: Aruba CX OVA on GNS3
    Posted Jun 22, 2020 05:45 PM
    Try gns3 application with gns3-vm without virtual-box. nested virtualization not supported by virtual box.
  • 3.  RE: Aruba CX OVA on GNS3
    Posted Jun 23, 2020 04:39 AM
    I tried with GNS3 VM, but while importing appliance getting checksum error.
    This is not the correct file. The MD5 sum is 094977687746989fad5aaa5303c9b41e and should be 79246d469649e090ef3cf8740bb38d12.
    Do you want to accept it at your own risks?
    I have downloaded the appliance file and OVA file from (AFP Portal) Arubapedia.
    I have attached the error screenshots also.
  • 4.  RE: Aruba CX OVA on GNS3
    Posted Jun 23, 2020 04:46 AM
    Ignore it, it will work
    Sent from Yahoo Mail on Android
  • 5.  RE: Aruba CX OVA on GNS3
    Posted Jun 23, 2020 04:53 AM
    I tired that,
    even after ignoring that error it shows under status that file is missing.
  • 6.  RE: Aruba CX OVA on GNS3
    Posted Jun 23, 2020 05:13 AM
    Allow Custom files on the same page at the bottom.
    see the attached snap
    if my post is helpful, give KUDOS
  • 7.  RE: Aruba CX OVA on GNS3
    Posted Jun 23, 2020 05:14 AM
    Please use the latest OVA 10.04.3000 from AFP (should be soon available on ASP as well). This includes more interfaces (9 dataplane + 1 for OOBM).
    For GNS3 appliance import, please refer to this doc attached.
    Simply select the file that is missing and import the proper vmdk file that is contains inside the OVA (use 7zip for instance to extract the vmdk from OVA package).
    Attachment(s)
    pdf
    ArubaOS-CX_OVA_GNS3_VM.pdf   907 KB 1 version
  • 8.  RE: Aruba CX OVA on GNS3
    Posted Jun 23, 2020 05:15 AM
    10.04.3000 has also IP-SLA (which was missing before).
    This allows to practice on NAE script that trigger action based on IP-SLA alert.
  • 9.  RE: Aruba CX OVA on GNS3
    Posted Jun 23, 2020 07:56 AM
    Thanks for the suggestions,
    Finally got it working....
    I extracted the OVA file and imported the vmdk file in gns3.
    Version : Virtual.10.04.0001
    I will try same with 10.04.3000 also.
