Wired Intelligent Edge
Aruba CX port-access dot1x repeating block/unblock round about every 10 minutes
This thread has been viewed 47 times
  • 1.  Aruba CX port-access dot1x repeating block/unblock round about every 10 minutes
    Posted Oct 21, 2021 08:39 AM
    Hi Guys,
    after replacing some old Aruba-OS Client Access Switches (2810, 2530 etc) with the new Aruba-CX Client Access Switches (6200F) we do have some trouble with our printers.
    The printers do have a self signed certificate and port-access is granted by dot1x with aruba clearpass.
    Principially it does work. But....:
    The log shows repeating port block and unblock in 10-minutes interval:
    2021-10-21T12:16:30.145560+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10503|LOG_INFO|MSTR|1|Port 2/1/38 is unblocked by port-access
    2021-10-21T12:16:30.135554+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10503|LOG_INFO|MSTR|1|Port 2/1/40 is unblocked by port-access
    2021-10-21T12:16:30.129388+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10503|LOG_INFO|MSTR|1|Port 1/1/37 is unblocked by port-access
    2021-10-21T12:16:29.945933+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10502|LOG_INFO|MSTR|1|Port 2/1/38 is blocked by port-access
    2021-10-21T12:16:29.933452+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10502|LOG_INFO|MSTR|1|Port 2/1/40 is blocked by port-access
    2021-10-21T12:16:29.907307+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10502|LOG_INFO|MSTR|1|Port 1/1/37 is blocked by port-access
    2021-10-21T12:06:30.310630+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10503|LOG_INFO|MSTR|1|Port 2/1/38 is unblocked by port-access
    2021-10-21T12:06:30.113784+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10502|LOG_INFO|MSTR|1|Port 2/1/38 is blocked by port-access
    2021-10-21T12:05:30.191547+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10503|LOG_INFO|MSTR|1|Port 2/1/40 is unblocked by port-access
    2021-10-21T12:05:30.090960+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10502|LOG_INFO|MSTR|1|Port 2/1/40 is blocked by port-access
    2021-10-21T11:54:30.042322+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10503|LOG_INFO|MSTR|1|Port 1/1/37 is unblocked by port-access
    2021-10-21T11:54:29.916321+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10503|LOG_INFO|MSTR|1|Port 2/1/40 is unblocked by port-access
    2021-10-21T11:54:29.904589+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10503|LOG_INFO|MSTR|1|Port 2/1/38 is unblocked by port-access
    2021-10-21T11:54:29.776992+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10502|LOG_INFO|MSTR|1|Port 1/1/37 is blocked by port-access
    2021-10-21T11:54:29.720679+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10502|LOG_INFO|MSTR|1|Port 2/1/40 is blocked by port-access
    2021-10-21T11:54:29.716880+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10502|LOG_INFO|MSTR|1|Port 2/1/38 is blocked by port-access
    2021-10-21T11:45:00.024908+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10503|LOG_INFO|MSTR|1|Port 2/1/38 is unblocked by port-access
    2021-10-21T11:44:59.937057+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10502|LOG_INFO|MSTR|1|Port 2/1/38 is blocked by port-access
    2021-10-21T11:44:30.174179+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10503|LOG_INFO|MSTR|1|Port 2/1/40 is unblocked by port-access
    2021-10-21T11:44:30.132218+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10503|LOG_INFO|MSTR|1|Port 2/1/37 is unblocked by port-access
    2021-10-21T11:44:30.128373+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10503|LOG_INFO|MSTR|1|Port 1/1/37 is unblocked by port-access
    2021-10-21T11:44:29.962611+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10502|LOG_INFO|MSTR|1|Port 2/1/40 is blocked by port-access
    2021-10-21T11:44:29.952958+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10502|LOG_INFO|MSTR|1|Port 2/1/37 is blocked by port-access
    2021-10-21T11:44:29.912622+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10502|LOG_INFO|MSTR|1|Port 1/1/37 is blocked by port-access
    2021-10-21T11:35:29.734719+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10503|LOG_INFO|MSTR|1|Port 1/1/37 is unblocked by port-access
    2021-10-21T11:35:29.647509+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10502|LOG_INFO|MSTR|1|Port 1/1/37 is blocked by port-access
    2021-10-21T11:34:59.723785+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10503|LOG_INFO|MSTR|1|Port 2/1/38 is unblocked by port-access
    2021-10-21T11:34:59.621648+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10502|LOG_INFO|MSTR|1|Port 2/1/38 is blocked by port-access
    2021-10-21T11:34:30.247033+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10503|LOG_INFO|MSTR|1|Port 2/1/37 is unblocked by port-access
    2021-10-21T11:34:30.235149+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10503|LOG_INFO|MSTR|1|Port 2/1/40 is unblocked by port-access
    2021-10-21T11:34:30.110471+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10502|LOG_INFO|MSTR|1|Port 2/1/37 is blocked by port-access
    2021-10-21T11:34:30.107721+02:00 vsf-vw-2og-01 port-accessd[3619]: Event|10502|LOG_INFO|MSTR|1|Port 2/1/40 is blocked by port-access
    Some employees have reported problems with printing and scanning (scan to e-mail).
    Today I had the same problem. I tried to scan-to-mail something but without success. Some minutes later a tried again, and then it works.
    Watching the switch logs, there was an entry for the time I tried to scan at first (11:54)
    time between blocking and unblocking is less a second, but printer log says that three attemps to reach the mail server were not successfully.
    My  question is... why there is a repating blocking and unblocking by port-access round about every 10 minutes? And how can I stop it?
    Not sure if the scanning problem really comes from the port-access, but cause of time-relation I would guess so.
    Configuration Output:
    New AOS-CX:
    aaa group server radius EWR
    aaa authentication port-access dot1x authenticator
    interface 1/1/37
        no shutdown
        description Printer
        vlan access 2480
        spanning-tree bpdu-guard
        spanning-tree root-guard
        spanning-tree tcn-guard
        spanning-tree port-type admin-edge
            cached-reauth
            eapol-timeout 20
            max-retries 5
            quiet-period 30
            enable
        loop-protect
        exit
    Old AOS-S:
    aaa authentication port-access eap-radius
    aaa port-access authenticator 23
    aaa port-access authenticator 23 quiet-period 30
    aaa port-access authenticator 23 tx-period 10
    aaa port-access authenticator 23 supplicant-timeout 8
    aaa port-access authenticator 23 server-timeout 20
    aaa port-access authenticator 23 max-requests 5
    aaa port-access authenticator 23 client-limit 1
    aaa port-access 23 controlled-direction in
    The port-access statistics show session duration much longer than the 10-minutes-interval:
    Session Time : 6148s = 102 minutes
    Reauthentication Period : 10800 secs = 180 minutes = 3 hours
    vsf-vw-2og-01# sh port-access clients detail
    Port Access Client Status Details:
    Client 00:20:6b:b4:7f:60, dot1x-drucker
      Session Details
        Port         : 1/1/37
        IPv4 Address :
        IPv6 Address :
      VLAN Details
        VLAN Group Name :
        VLANs Assigned  : 2480
          Access          : 2480
          Native Untagged :
          Allowed Trunk   :
      Authentication Details
        Status          : dot1x Authenticated
        Auth Precedence : dot1x - Authenticated, mac-auth - Not attempted
        Auth History    : dot1x - Authenticated, 6148s ago
      Authorization Details
        Role   : RADIUS_3820372328
        Status : Applied
    Role Information:
    Type  : radius
        Cached Reauthentication Period      :
        Authentication Mode                 :
        Session Timeout                     :
        Client Inactivity Timeout           :
        Description                         :
        Gateway Zone                        :
        UBT Gateway Role                    :
        UBT Gateway Clearpass Role          :
        Access VLAN                         : 2480
        Native VLAN                         :
        Allowed Trunk VLANs                 :
        Access VLAN Name                    :
        Native VLAN Name                    :
        Allowed Trunk VLAN Names            :
        VLAN Group Name                     :
        MTU                                 :
        QOS Trust Mode                      :
        STP Administrative Edge Port        :
        PoE Priority                        :
        Captive Portal Profile              :
        Policy                              :
    Thanks and Kind Regards
    Robert
    Robert Großmann
  • 2.  RE: Aruba CX port-access dot1x repeating block/unblock round about every 10 minutes
    Posted Oct 22, 2021 05:24 AM
    Looking at the clearpass site, it does look weird, too. Recurring timeout and accept...:
    Robert Großmann
  • 3.  RE: Aruba CX port-access dot1x repeating block/unblock round about every 10 minutes
    Posted Oct 22, 2021 11:04 AM
    I see these are printers? Could it be that after 10 minutes your printer goes in 'sleep mode', or 'energy efficient' mode which may put the interface from gigabit to 100Mbps or so?
    Do you see this just with printers? Or also with other devices?
  • 4.  RE: Aruba CX port-access dot1x repeating block/unblock round about every 10 minutes
    Posted Oct 25, 2021 02:23 AM
    Hi Herman,
    I don't know why, but printers are the only devices where the switchports are protected by dot1x.
    Maybe because the RJ45 ports are "public" (floor and not office).
    I don't think that it has something to do with sleep mode because It does not happen on the old switch.
    Also I had copied something and then scanned something, so that the multi-function-printer (Konica Minolta) was powered on.
    Kind Regards
    Robert
    Robert Großmann
  • 5.  RE: Aruba CX port-access dot1x repeating block/unblock round about every 10 minutes
    Posted Oct 25, 2021 05:09 AM
    It may be best to work with TAC and let them run debug or troubleshooting commands to find out why the switch is de-authorizing the client and run a new authentication as I agree it doesn't look as expected.
  • 6.  RE: Aruba CX port-access dot1x repeating block/unblock round about every 10 minutes
    Posted Oct 26, 2021 02:47 AM
    I also had a similar issue with printers and timestamp machines on a 6300CX which are suspected to enter sleep mode after a while. I tweaked some parameters but due to operational pressurre had to remove dot1x from the port.
    So, please do share the findings and fix from TAC :)
  • 7.  RE: Aruba CX port-access dot1x repeating block/unblock round about every 10 minutes
    Posted Nov 23, 2022 04:19 AM
    for me it has helped to use the parameter "client-inactivity timeout none"
    Be aware:
    Konica Minolta Devices okay
    Ricoh devices not completely okay. They don't support re-auth or there is an issue. By ERe-Auth and Session-Timeout the port is blocked for about 1 minute. The Problem has something to do with the tls encryption. So we disable reauth for Ricoh printers and set session timeout to 24h.
    Up to now we do not got a solution from Ricoh.
    It can be done with local port-access-roles, like:
    port-access role PRINTER
        auth-mode client-mode
        session-timeout 86400
        trust-mode none
        stp-admin-edge-port
        vlan access 2480
    ! locally assigned port-access role
    interface 1/1/37
        no shutdown
        description Printer
        no routing
        vlan access 999
        aaa authentication port-access client-limit 2
        aaa authentication port-access auth-role PRINTER
        aaa authentication port-access reject-role QUARANTAENE
        ! aaa authentication port-access radius-override enable
        port-access allow-flood-traffic enable
            eapol-timeout 10
            max-retries 5
            quiet-period 30
            discovery-period 10
            enable
        client track ip update-interval 300
        loop-protect
    ! parameters by radius or radius assigned port-access role
    interface 1/1/37
        no shutdown
        description Printer
        no routing
        vlan access 999
            eapol-timeout 10
            max-retries 5
            quiet-period 30
            discovery-period 10
            enable
        loop-protect
    The CPPM (Clearpass Policy Manager) equivalent is idle-timeout = 0 (Type Radius:IETF).
    To assign a locally configured port-access role by radius use Aruba-User-Role = e.g. PRINTER (Type Radius:Aruba)
    Using Aruba Downloadable Roles it is Client Inactivity Timeout = None
