Wired Intelligent Edge
  • 1.  ARUBA CX SImulator Tacacs Integration doesn't Work
    Posted Oct 12, 2021 11:54 AM
    Dear All,
    I did some tests for future projects using GNS3 lab, here is the detail for the environment:
    1. GNS3 as Image orchestrator running on Virtual Box
    2. Aruba CX OVA simulator running on Virtual Box
    3. Tacacs GUI for TACACS+ Server running on Virtual Box
    4. Webterm as end device that will test SSH to Devices
    The topology is like this:
    the following is the command that I run on the ARUBA CX SWITCH.
    ssh server vrf default
    tacacs-server key plaintext tacacs1234
    tacacs-server host 10.1.1.100 vrf default
    aaa group server tacacs TACACS-GUI
    server 10.1.1.100 vrf default
    aaa authentication login default group TACACS-GUI local
    aaa authentication login ssh group TACACS-GUI local
    From the TACACS GUI LOG, PAP Authentication has been successful but access to the switch is still denied, as folows:
    Did I miss something?
    Thank you very much for the help.
    Sincerely,Gibs
    Luthfi Naufal Gibrani
  • 2.  RE: ARUBA CX SImulator Tacacs Integration doesn't Work
    Posted Nov 03, 2021 01:50 AM
    i've also just had the same experience trying to run this from EVE into ClearPass.
    Scott Doorey
  • 3.  RE: ARUBA CX SImulator Tacacs Integration doesn't Work
    Posted Nov 04, 2021 03:24 AM
    tacacs-server host clearpass.selectium.local key plaintext pasword auth-type pap vrf mgmt
    aaa group server tacacs Clearpass-Tacacs
    server clearpass.selectium.local vrf mgmt
    aaa authentication login default group Clearpass-Tacacs local
    aaa authorization commands default group Clearpass-Tacacs
    aaa accounting all-mgmt default start-stop group Clearpass-Tacacs
    On ClearPass side the enforcement profile is looking like this. Instead of priv-lvl you can also use roles. This would be even better, but for my case, priv-lvl is enough.
    Profile:
    Name:
    ArubaOS-CX TACACS Management RW Access
    Description:
    TACACS+ Management RW access for ArubaCX switches
    Type:
    TACACS+
    Action:
    Accept
    Device Group List:
    1. ArubaOS-CX switches
    Services:
    Privilege Level:
    15
    Selected Services:
    1. Shell
    2. Aruba:Common
    Authorize Attribute Status:
    ADD
    Custom Services:
    Service Attributes
      Type Name = Value
    1. Shell priv-lvl = 15
    Commands:
    Service Type:
    shell
    Unmatched Commands:
    Permit
    Commands
      Command Arguments Permit Action Unmatched Arguments
    Best, Gorazd
    Gorazd Kikelj
