Wired Intelligent Edge
Aruba CX Simulator with GNS3 , high pings
This thread has been viewed 74 times
  • 1.  Aruba CX Simulator with GNS3 , high pings
    Posted Jan 21, 2022 06:36 AM
    Edited by ubercal Jan 21, 2022 06:49 AM
    When setting up STP between 4 switches with reduncy , the pings between pcs on the same network as well as across the vlans is very high.This only happens when spanning tree is enabled.My PC us running GNS3 with vmware workstation pro.The pc has plenty of memory 32GB Ram with a core i7 processor.Ive tried all versions of the cx simulator vm , and they all do the same.Is there a known bug with the simulator and spanning tree ?
    Cal Rose
  • 2.  RE: Aruba CX Simulator with GNS3 , high pings
    Posted Jan 21, 2022 07:26 AM
    Ok after looking through the other threads , i see that i might have "hit the stp limiter".Does anybody from Aruba know if there are plans in place to fix this issue in the near future ?
    Cal Rose
