Wired Intelligent Edge
Aruba CX Switch HTTPS TACACS Web Authentication
This thread has been viewed 48 times
  • 1.  Aruba CX Switch HTTPS TACACS Web Authentication
    Posted Feb 23, 2021 09:31 AM
    Having some trouble getting the HTTPS web authentication to work when logging into the switch GUI with TACACS but the local switch admin still works.
    Anyone have any insight into this?
    SSH TACACS works great after applying the fragmentation patch. I have allowed level 15 and administrator role in the enforcement profile I just do not see the attempt even making it to ClearPass for the web gui login. Nothing in the event viewer. Here are the CX switch commands I have deployed.
    aaa authentication login https-server group CP-TEST-TACACS local (Allow HTTPS Login from TACACS? then Local)
    aaa authentication login ssh group CP-TEST-TACACS local (Allow SSH Login from TACACS then Local)
    aaa authorization commands ssh group CP-TEST-TACACS (Authorize SSH commands against TACACS)
    aaa accounting all-mgmt https-server start-stop group CP-TEST-TACACS (Account HTTPS mgmt commands to TACACS)
    aaa accounting all-mgmt ssh start-stop group CP-TEST-TACACS (Account SSH mgmt commands to TACACS)
    aaa accounting port-access start-stop interim 5 group CP-TEST-RADIUS (Account 802.1x port to RADIUS)
    Christopher Calhoun
  • 2.  RE: Aruba CX Switch HTTPS TACACS Web Authentication
    Posted Aug 18, 2021 03:50 PM
    Did you get this figured out?   I'm having same issue.
    Alan Scott
  • 3.  RE: Aruba CX Switch HTTPS TACACS Web Authentication
    Posted Aug 19, 2021 04:08 AM
    Had the same problem, Clearpass required some tweaking to get TACACS working on the GUI.
    This is what i have configured in CP, maybe it helps
  • 4.  RE: Aruba CX Switch HTTPS TACACS Web Authentication
    Posted Aug 19, 2021 01:23 PM
    Thanks for sharing I will take a look at that.
    Alan Scott
  • 5.  RE: Aruba CX Switch HTTPS TACACS Web Authentication
    Posted 29 days ago
    Please try to add AMP:https role Admin into Services.
    Give me a Kudo when this is useful.
    Ratchapas
    https://www.facebook.com/Aruba-News-Update-1401095559960142
  • 6.  RE: Aruba CX Switch HTTPS TACACS Web Authentication
    Posted May 16, 2024 06:30 AM
    TACACS+ is for CLI, RADIUS will be GUI based like the HTTPS Web UI for the switch. You will want to create a Radius profile (Aruba RADIUS Enforcement) then its attributes will be Radius:Aruba Name: Aruba-User-Role and value=administrators. The CX switch has built in group for administrators called administrators. This enforcement profile will get you into the HTTP GUI using RADIUS, since TACACS is for only CLI.
