Yes.
Original Message:
Sent: Feb 12, 2024 10:59 AM
Subject: Aruba CX switch is not in sync with aruba central
was the issue resolved after enabling aruba-central?
Original Message:
Sent: Feb 10, 2024 09:38 AM
We actually had this exact thing happen. We were not using templates on this particular set of switches, so if you are this would not be the problem.
In order to make some changes for testing the engineer did an aruba-central disable, and forgot to enable afterwards. Everything showed as yours does. Just a possability.
Original Message:
Sent: Feb 09, 2024 02:07 AM
Hi ariyap,
no, we have not moved the device to another central account.
below is the show Aruba-central output as requested :
eff-n-cin-sw-as1# sh aruba-central
Central admin state : enabled
Central location : device-uswest4-d2.central.arubanetworks.com
VRF for connection : default
Shared Token : N/A
Central connection status : connected
Central source : activate
Central source connection status : connected
Central source last connected on : Sun Dec 17 03:33:39 UTC 2023
System time synchronized from Activate : True
Activate Server URL : devices-v2.arubanetworks.com
CLI location : N/A
CLI VRF : N/A
Source IP : 10.78.82.12
Source IP Overridden : True
Central support mode : disabled
Original Message:
Sent: Feb 09, 2024 01:38 AM
have you moved those switches to another Central account? and if you can paste the output of "show aruba-central" for those offline switches
Original Message:
Sent: Feb 08, 2024 09:34 PM
The issue is that the switch shows as connected to central on the switch CLI but on the central UI it shows as offline .
The switch firmware is 10.10.1071
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/bf8c446f9bd948a48fe5efae4339989f.png)
