Original Message:
Sent: Nov 23, 2023 09:05 AM
Subject: Aruba CX Switch not receiving the Role
Hello
Which debug commands can I use to see the information received from clearpass?
Original Message:
Sent: Nov 17, 2023 05:08 PM
see if you can upgrade to 10.10.1090 firmware.
there was a resolved case where Clients are not updated with the latest role
Original Message:
Sent: Nov 17, 2023 03:32 AM
Hello ariyap
I tried again. no logs from radius
All i have
Original Message:
Sent: Nov 16, 2023 07:56 PM
just reconnect the camera and then see the output of show event -r
Original Message:
Sent: Nov 16, 2023 06:59 PM
Hello ariyap, thank you for the reply
Form the show event -r i cannot see any log from radius
With the sh port-access clients det i can see the default role
Original Message:
Sent: Nov 16, 2023 06:32 PM
see if these commands can shed more light.
"show event -r" and "sh port-access clients det"
Original Message:
Sent: Nov 16, 2023 06:04 AM
Aruba CX Switch 6100 - version PL.10.10.1070
Clearpass version 6.11.1.2513.04 (Cloud)
Hello Everyone we are testing Clearpass for future implementation (POC with Trial Version)
At the moment I was able to authenticate the user, Enforce the profile (with user role) to send to the Switch but i am facing a problem. On the switch side the port is not enforced with the correct Role
I created the LUR-CX-CAMERA on the Enforcement Profile
From Access tracker I am able to confirm the profile is correctly matching the device
On the switch side I have the role created with the same name
But the switch is assigning the default RADIUS_0 role
Any idea about the issue? How can I troubleshoot this?
Regards
Tony
