Wired Intelligent Edge
Aruba CX switches and EVE-NG simulator - minimum CPU model requirement
This thread has been viewed 19 times
  • 1.  Aruba CX switches and EVE-NG simulator - minimum CPU model requirement
    Posted Nov 28, 2023 04:57 AM
    does CX virtual switches / EVE-NG simulator have some sort of CPU instruction requirement to be able to work?
    I have the problem where it runs on top of E5-2680 v2 CPU's in ESXi 7.0.
    The CX switches boot up and can be managed in CLI without problems.
    But there is a weird thing going on when I try to use NetEdit v2.9 to make changes to these switches.
    All CX switches go to hardware reset and start rebooting every time I click deploy button in NetEdit.
    My NetEdit is running as a separate ESXi VM.
    So I started to wonder maybe my CPU is too old and does not have some instructions required by CX virtual switches or EVE-NG?
    What could be the cause of the problem? I have 20 CPU cores, 40 threads and 196GB RAM.
    EVE-NG has 20 cores and 64GB RAM which should be more than enough to run 3 CX switches for a lab - so the problem is not hardware resource related.
  • 2.  RE: Aruba CX switches and EVE-NG simulator - minimum CPU model requirement
    MVP EXPERT
    Posted Nov 28, 2023 05:24 PM
    Far a i known EVE-NG or CX Simulator don't have any CPU requirement other than is have to support Intel Virtualalization.
    https://www.eve-ng.net/index.php/documentation/installation/system-requirement/
    https://www.arubanetworks.com/techdocs/AOS-CX/10.13/OVA/rn_ova_10.13.0005.pdf
    Note: 10.13.xxxx is available since this week ;)
    I run EVE-NG on a Intel NUC Gen7 with Corei7 4core / 32b ram / NVMe / VMware 6.7. Can run up to 6-8 virtual switches. Didn't test it with NedEdit unfortunally.
    I don't think your hardware is the issue.
    Marcel Koedijk | MVP Expert 2023 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
  • 3.  RE: Aruba CX switches and EVE-NG simulator - minimum CPU model requirement
    MVP EXPERT
    Posted Nov 29, 2023 12:26 PM
    My setup runs without issues with two virtual switches. Can push configuration like time settings from NetEdit and are commit successfull.
    • ArubaOS-CX:Virtual.10.13.0005
    • NetEdit 2.9.0
    • Intel NUC Gen7 Corei7 / 32GB Ram
    • VMware 6.7U3
    • EVE-NG 5.0.1-13-Community
