Wired Intelligent Edge
Aruba CX 'Voice' command
Jump to Best Answer
  • 1.  Aruba CX 'Voice' command
    Posted Jun 15, 2022 11:41 AM
    What does the vlan command 'voice' actually do?
    Can't find the detail in any documentation.
  • 2.  RE: Aruba CX 'Voice' command
    Posted Jun 15, 2022 01:14 PM
    Configures a VLAN as voice VLAN. This command defines which VLAN (if any) will be advertised to the MED-capable endpoints as Voice VLAN over LLDP-MED.
    Important note: This setting doesn't prioritize the traffic inside the VLAN that has been defined as Voice VLAN, e.g. it has nothing to do with QoS, you need to set it up additionally.
    Hope this helps!
    Ivan Bondar
  • 3.  RE: Aruba CX 'Voice' command
    Posted Jun 16, 2022 03:31 AM
    Thanks Ivan_B. Very helpful.
    I had suspected as much although the CX documentation very much seems to be a 'work in progress'. :D
