Network Management
Aruba CX6000 Switch - IP Helper Address
This thread has been viewed 16 times
  • 1.  Aruba CX6000 Switch - IP Helper Address
    Posted Apr 07, 2022 08:27 AM
    we have bought a CX6000 Switch and want configure the ip-helper addresses.
    But the CLI command for the ip-helper doesn't exists, is it not possible to configure this on the CX6000 Switch?
    Thank you for your help and kind regards
    Karl
    Karl Winkler
  • 2.  RE: Aruba CX6000 Switch - IP Helper Address
    MVP GURU
    Posted Apr 07, 2022 03:59 PM
    I don't believe it is an option on the 4100i, 6000, and 6100 series.
    The proper CX syntax for the IP helper is below. If you do not see the options to set these, then it would be a limitation of the switch series. You may have to be at least on the 6200 series or higher for the DHCP relay service:
    interface <vlan/interface>
    ip address xxx.xxx.xxx.xxx/xx
    ip helper-address xxx.xxx.xxx.xxx
    exit
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
