Aruba design of the machine authentication
This thread has been viewed 22 times
  • 1.  Aruba design of the machine authentication
    Posted Jul 22, 2022 03:21 PM
    dears
    we want documentaion to Aruba design of the machine authentication
    how  machine authentication on aruba  work with raduis server and active directory
    and what is the recommende from aruba and best solution to use machine authentcation in network
  • 2.  RE: Aruba design of the machine authentication
    Posted Jul 22, 2022 07:27 PM
    Machine authentication is agnostic to the WLAN device.  Typically the radius server determines if there are any enhanced features to machine authentication.
  • 3.  RE: Aruba design of the machine authentication
    Posted Jul 22, 2022 07:42 PM
    here is an older guide to setup clearpass for machine/user auth, as you'll see you don't have to do anything on the controller or APs.
    https://community.arubanetworks.com/community-home/digestviewer/viewthread?MID=1920#bm3cc74933-7542-435e-b8fb-f7fad3506cc8
  • 4.  RE: Aruba design of the machine authentication
    Posted Jul 22, 2022 08:19 PM
    thanks for replay but i want documntaion aruba controller with eaduis server
    how machine authentication work
  • 5.  RE: Aruba design of the machine authentication
    Posted Jul 22, 2022 08:20 PM
    thanks i tried to get the documntaion but no luck
  • 6.  RE: Aruba design of the machine authentication
    Posted Jul 22, 2022 08:44 PM
    here is the documentation link for AOS8.x
    look under authentication
    https://www.arubanetworks.com/techdocs/ArubaOS_8.8.0_Web_Help/Content/home.htm
