Aruba Firmare - Advisory ID: ARUBA-PSA-2016-004
  • 1.  Aruba Firmare - Advisory ID: ARUBA-PSA-2016-004
    Posted May 05, 2016 03:43 PM
    I was send the follwoing today
    CVE: CVE-2016-2031
    Publication Date: 2016-May-04
    Status: Confirmed
    Revision: 1
    Please can someone explain the Aruba firmware release  pattern / naming convention.
    The advisory says that Aruba Instant (all versions up to, but not including, 4.1.3.0 and 4.2.3.1) are affected but sorry to sound stupid but the current relased is 6.4.4.4-4.2.3.1_54637 and this is for 4.xxxx. Also when was the 'safe' version of Aruba instant firmware relased?
    Jason
  • 2.  RE: Aruba Firmare - Advisory ID: ARUBA-PSA-2016-004
    Posted May 06, 2016 08:49 AM
    My guess is that the 4.x.x.x refers to the middle part of the full version number. I.e. 6.4.4.4-4.2.3.1_54637 = 4.2.3.1. And 6.4.4.4-4.2.3.1 is the latest release in the Early Deployment branch.
    But that still doesn't explain where 4.1.3.0 can be downloaded. The latest release in the General Availability branch is 6.4.2.6-4.1.1.12 (I.e. 4.1.1.12 if my theory is correct) and the Early Deployment branch only have 4.2.x.x versions.
  • 3.  RE: Aruba Firmare - Advisory ID: ARUBA-PSA-2016-004
    Posted May 08, 2016 08:10 AM
    The full Aruba Instant version numbers is built up like: <ArubaOS base version>-<Aruba Instant version>_<build number>.
    The ArubaOS base version defines from which Controller release this Instant version has been derived, and is there for information purposes only; the same for the Build Number.
    So in most cases you only take the middle part 4.x.x.x into account.
    Aruba Instant firmware is available without support contract from the 'Check new version' in the Maintenance tab in the virtual controller, or via the support website under Life time warranty software: http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/Default.aspx. At this moment 4.1.1.12 and 4.2.2.0 are the available versions.
    Version 4.1.3.0 has not been released yet, you may work with Aruba TAC to get an estimated release date.
  • 4.  RE: Aruba Firmare - Advisory ID: ARUBA-PSA-2016-004
    Posted May 09, 2016 12:13 PM
    I'm sitting on 4.1.1.11 and have been checking for firmware since the bulletins have come out under Maintenance.  It won't pull any updates down.
    You can update manually by URL.  What URL should we be using?
  • 5.  RE: Aruba Firmare - Advisory ID: ARUBA-PSA-2016-004
    Posted May 09, 2016 12:18 PM
    The lifetime warranty software available at the moment is here 4.2.2.0
    http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/Default.aspx?EntryId=20388
  • 6.  RE: Aruba Firmare - Advisory ID: ARUBA-PSA-2016-004
    Posted May 09, 2016 01:01 PM
  • 7.  RE: Aruba Firmare - Advisory ID: ARUBA-PSA-2016-004
    Posted May 09, 2016 03:12 PM
    In reference to the URL, I'm referring to the box on the Maintenance > Firmware page where it asks for URL for manual updating.
  • 8.  RE: Aruba Firmare - Advisory ID: ARUBA-PSA-2016-004
    Posted May 09, 2016 03:29 PM
    you can use HTTP, TFTP, FTP (anonymous only). from user guides:
    Select the Image URL option. Select this option to obtain an image file from a TFTP, FTP, or HTTP URL.
    n HTTP - http://<IP-address>/<image-file>. For example, http://<IP-address>/ArubaInstant_Orion_6.4.4.4-
    4.2.3.0.0_xxxx
    n TFTP - tftp://<IP-address>/<image-file>. For example, tftp://<IP-address>/ArubaInstant_Orion_6.4.4.4-
    4.2.3.0.0_xxxx
    n FTP - ftp://<IP-address>/<image-file>. For example, ftp://<IP-address>/ArubaInstant_Orion_6.4.4.4-
    4.2.3.0.0_xxxx
