Aruba Firmware to Support 802.11ac
  • 1.  Aruba Firmware to Support 802.11ac
    Posted Nov 19, 2013 10:33 AM
    Hi, Does anyone know what version of AOS the Aruba Instant's need to be on to support 802.11ac?
  • 2.  RE: Aruba Firmware to Support 802.11ac
    Posted Nov 19, 2013 11:12 AM
    v.4.0 will support the new IAPs (IAP-22x and IAP-11x).  Initially, it will be posted to the TAC site under SW downloads.   Look for it by the end of this week or next week.
  • 3.  RE: Aruba Firmware to Support 802.11ac
    Posted Nov 19, 2013 11:14 AM
    OK Great Thanks, will this be ok for AP-135;s and AP105's?
  • 4.  RE: Aruba Firmware to Support 802.11ac
    Posted Nov 19, 2013 11:16 AM
    v.4.0 supports all IAP models.
    Just for clarity...........You mentioned AP-135 and AP-105; however, those are controller-based APs and require a controller.  The IAP-135 and IAP-105 can run IAP v.4.0.
  • 5.  RE: Aruba Firmware to Support 802.11ac
    Posted Nov 19, 2013 11:19 AM
    Instant 4.0 for the 105 and 135 models is available on the support site as
    of yesterday.
  • 6.  RE: Aruba Firmware to Support 802.11ac
    Posted Nov 19, 2013 11:21 AM
    Good to hear!  Was targeted for end of the week.  Thanks for the post.
  • 7.  RE: Aruba Firmware to Support 802.11ac
    Posted Nov 19, 2013 11:44 AM
    Be sure to grab the right AP image from http://support.arubanetworks.com.  Only the last version supports 802.11ac.
    Orion: RAP3, IAP92/93,IAP104/105, IAP175
    Cassiopeia: IAP134/135
    Pegasus: RAP108/109, IAP114/115
    Aries: RAP155/155P
    Ardmore: IAP224/225 (802.11ac)
  • 8.  RE: Aruba Firmware to Support 802.11ac
    Posted Nov 19, 2013 11:47 AM
    For a summary of the IAP 4.0 features Click Here and scroll to the end of the list.
  • 9.  RE: Aruba Firmware to Support 802.11ac
    Posted Nov 27, 2013 03:59 AM
    Thanks so much guys!
