Aruba Forgot Password
  • 1.  Aruba Forgot Password
    Posted Jul 21, 2012 10:45 AM
    Dear All,
    How to reset Aruba 650? Because I forgot the password.
    Thank you.
  • 2.  RE: Aruba Forgot Password
    Posted Jul 21, 2012 10:47 AM
    Password Recovery
    Please login using console with a serial cable (e.g. you must be infront of the controller):
    Login : password
    Password: forgetme!
    Then go into enable mode with pwd “enable”
    Config terminal
    Mgmt-user admin root
    <hit enter and it will ask you for a new root password>
    logout and login back in
    Then wr mem
    Then power off/on
  • 3.  RE: Aruba Forgot Password
    Posted Jul 22, 2012 10:17 PM
    Is there any other ways to reset the password? Such as by pressing the stop button at the controller?
    Thanks.
  • 4.  RE: Aruba Forgot Password
    Posted Jul 22, 2012 11:19 PM
    No need to answer my second question.
    Thank you sir.
