Aruba Guest captative portal with sponsorship
  • 1.  Aruba Guest captative portal with sponsorship
    Posted Sep 06, 2017 02:48 PM
    Hi All,
    I am settingup the Aruba Guest captative portal with sponsroship.
    I have looked at different documentation,but looks there is no proper document to explain on how to setup this.
    I am able to connect to the guest wirless and get the ip address from the DHCP,however i am not able to redirect to the self registartion page.
    In the CPM tracker, i see the request is rejected.
    Any pointers to the correct setps of configuration or a document is much appreciated.
  • 2.  RE: Aruba Guest captative portal with sponsorship
    Posted Sep 06, 2017 03:04 PM
    This ase solution should get you going:
    https://ase.arubanetworks.com/solutions/id/92
    Get Outlook for iOS
  • 3.  RE: Aruba Guest captative portal with sponsorship
    Posted Sep 06, 2017 03:30 PM
    but this one doesnt talk about the configuration required on the CPM and the controller..
  • 4.  RE: Aruba Guest captative portal with sponsorship
    Posted Sep 06, 2017 03:51 PM
    If you follow all the instructions listed , you will see everything (including the controller configuration)
