last person joined: 9 hours ago
Aruba iAP 103 update
  • 1.  Aruba iAP 103 update
    Posted Jun 06, 2020 03:14 PM
    i have a RAP 155 and i update the FW to ArubaInstant_Aries_6.5.4.3_61959
    Also i have iAP 103 with FW 6.5.4.16 and i want to update to
    ArubaInstant_Pegasus_6.5.4.3_61959
    but the 103 are do nothing, just hanging in upgrade but nothing happens.
    The RAP155 are offline at this time.
    Also i have 5x 103 but when i log in i see only
    0 AP but all working and have the same FW.
    cu
  • 2.  RE: Aruba iAP 103 update
    MVP GURU
    Posted Jun 07, 2020 08:59 PM
    Have you tried a factory reset on all of the AP-103 access points? Are they all on the same VLAN/Subnet?
  • 3.  RE: Aruba iAP 103 update
    Posted Jun 08, 2020 09:51 AM
    From the beginning i make a rest of all.
    All AP are running i see them when i scanning the network.
  • 4.  RE: Aruba iAP 103 update
    MVP GURU
    Posted Jun 08, 2020 10:03 AM
    Have you tried installing the firmware via CLI?
  • 5.  RE: Aruba iAP 103 update
    Posted Jun 08, 2020 12:15 PM
    No over the Web Frontend
  • 6.  RE: Aruba iAP 103 update
    MVP GURU
    Posted Jun 08, 2020 12:21 PM
    Can you try upgrading one of the AP-103s with the other APs disconnected from the network? If and when that AP upgrades, bring up the remaining APs and see if they join the cluster and upgrade as well.
  • 7.  RE: Aruba iAP 103 update
    Posted Jun 08, 2020 03:24 PM
    Puuhhh, alternative?
    When i upgrade without disconnect?
    cu
