Aruba IAP 105 Bandwidth throttled to 60%
  • 1.  Aruba IAP 105 Bandwidth throttled to 60%
    Posted May 28, 2018 12:26 AM
    I'm not able to get complete internet bandwidth even if Transmit rate is 300 Mbps. My input internet bandwidth is 250Mbps. Even at TX 300Mbps, I see max 160Mbps with speedtest.net  If I get any other router/access point, I do get 250Mbps. I see the bandwidth is always throttled to 60% of transmit rate available. This is not the case with other Wi-Fi routers I was testing. I'm on firmware version 6.4.4.4-4.2.3.2_54910
    Here are few settings which I have tried:
    ARM
    Band steering mode: 5Ghz
    Airtime fairness mode: Preferred Access
    Min transmit power: 12
    Max transmit power: Max
    WLAN setting
    Broadcast filtering: ARP
    Multicast transmission optimization: disabled
    Dynamic multicast optimization: disabled
    My full dump of running configs I have attached.
    Any pointers to resolve this issue would be of great help.
    Thanks!
    Attachment(s)
    txt
    aruba_dump.txt   253 KB 1 version
  • 2.  RE: Aruba IAP 105 Bandwidth throttled to 60%
    Posted May 28, 2018 03:48 AM
    The connection speed in Wireless is not equal to the TCP Throughput that you measure with a SpeedTest.
    First, there is a lot of error correction and other overhead second Wireless is a half-duplex medium. So the traffic from AP to the client shares the same 'airtime' with the traffic from client to AP. As a (very) rough estimate, if you get half of the link speed as TCP throughput in a linktest, the network is performing quite okay and that is expected.
    The numbers that you report seem pretty acceptable to me for a 300 Mbps 802.11n connection. You can't expect to get a speedtest at the rate something even near to the link speed.
    This advertised speed versus nominal TCP throughput is something across the industry where higher numbers look better on datasheets.
