Aruba IAP-105 - do settings need to be changed for horizontal vs. vertical positioning?
  • 1.  Aruba IAP-105 - do settings need to be changed for horizontal vs. vertical positioning?
    Posted May 19, 2014 12:25 PM
    Hi all,
    I seem to remember that some makes/models of access points used to have to have manual changes made to their configurations to support horizontal positioning instead of vertical.
    Is this the case with Aruba IAP-105 access points, and if so, where are the settings?
  • 2.  RE: Aruba IAP-105 - do settings need to be changed for horizontal vs. vertical positioning?
    Posted May 19, 2014 12:27 PM
    There are no settings for horizontal v. vertical mounting.  That being said, the IAP-105 does have a downtilt bias and is better suited for ceiling mounting.  Take a look at the AP-105 spec sheet for the antenna pattern.
  • 3.  RE: Aruba IAP-105 - do settings need to be changed for horizontal vs. vertical positioning?
    Posted May 21, 2014 11:26 AM
    With that in mind, when wall-mounting, is the IAP-104 and external antennas preferable?
