Aruba IAP-105 FW 6.1.3.1-3.0.0.1_33617 - Download...
This thread has been viewed 72 times
  • 1.  Aruba IAP-105 FW 6.1.3.1-3.0.0.1_33617 - Download...
    Posted Dec 01, 2017 05:40 AM
    Hi guys,
    Could someone please point me in the direction of a download link to firmware 6.1.3.1-3.0.0.1_33617 for IAP-105 access point?
    Many thanks.
    Adrian
  • 2.  RE: Aruba IAP-105 FW 6.1.3.1-3.0.0.1_33617 - Download...
    Posted Dec 01, 2017 06:13 AM
    That is from 2012.  Are you sure that is what you want?
  • 3.  RE: Aruba IAP-105 FW 6.1.3.1-3.0.0.1_33617 - Download...
    Posted Dec 01, 2017 06:30 AM
    Yes please, if you can that would be great.
  • 4.  RE: Aruba IAP-105 FW 6.1.3.1-3.0.0.1_33617 - Download...
    Posted Dec 04, 2017 02:59 AM
    You should not use this firmware as stability and security issues has been dramatically improved in newer releases. Click on the link if you are really sure and want to get that firmware (valid software subscription is required).
    For IAP-105, I would take the 6.4.4.8-4.2.4.9 release (https://support.arubanetworks.com/DownloadSoftware/tabid/75/DMXModule/510/Default.aspx?EntryId=26917); or here if you don't have an active support contract.
  • 5.  RE: Aruba IAP-105 FW 6.1.3.1-3.0.0.1_33617 - Download...
    Posted Aug 10, 2021 12:12 PM
    Do have the file?
    Bjorn Sundin
