Aruba IAP 205 - Received no response from server
This thread has been viewed 72 times
  • 1.  Aruba IAP 205 - Received no response from server
    Posted Oct 02, 2015 10:50 PM
    Hello everyone, i just got 3 IAP's setup in my environment and attempted to update the firmware only to be met by "Received no response from server" , my certificate expires Aug 11 of 2017; i saw in another thread if this was expired it wouldnt work.
    I can SSH into the IAP's and ping google with no issue, but i still cant reach out for updates.
    Current version is 6.4.2.0-4.1.1.0_46028 , they are all IAP 205's
  • 2.  RE: Aruba IAP 205 - Received no response from server
    Posted Oct 03, 2015 07:26 AM
    You cannot see the certificate that has expired.  I just sent you a link.
  • 3.  RE: Aruba IAP 205 - Received no response from server
    Posted Oct 03, 2015 01:13 PM
    Awesome! Yea that firmware did the trick, and i can now reach the update server where it says no update.
  • 4.  RE: Aruba IAP 205 - Received no response from server
    Posted Oct 25, 2016 04:11 AM
    I have the same problem too, i connect for SSH to de iap, and from iap ping to internet, but when i check firmware "no response from server"
  • 5.  RE: Aruba IAP 205 - Received no response from server
    Posted Oct 25, 2016 04:25 AM
    What version of Firmware are you running?  As a possible fix to your problem, you can upgrade to the version here:  http://support.arubanetworks.com/LifetimeWarrantySoftware/tabid/121/DMXModule/661/EntryId/21998/Default.aspx
  • 6.  RE: Aruba IAP 205 - Received no response from server
    Posted Oct 25, 2016 04:35 AM
    i Have two models in my network the iap 105 and the iap 103, is the same firmware?
  • 7.  RE: Aruba IAP 205 - Received no response from server
    Posted Oct 25, 2016 04:42 AM
    No.  Please look at the diagram here:
    105 is Orion and 103 is Pegasus.
  • 8.  RE: Aruba IAP 205 - Received no response from server
    Posted Oct 25, 2016 04:47 AM
    thanks!!, but how can i upload the firmware from a file?, in the url can i put a ftp internal address?
  • 9.  RE: Aruba IAP 205 - Received no response from server
    Posted Oct 25, 2016 04:55 AM
    Yes, you need to have an ftp internal address for both.  It must be an anonymous ftp with no username and password.  A  tftp server might be easier, because it doesn't use a password.  Use the format:
    ftp://xx.xx.xx.xx/ArubaInstant....
    tftp://xx.xx.xx.xx/ArubaInstant....
  • 10.  RE: Aruba IAP 205 - Received no response from server
    Posted Oct 29, 2016 03:04 PM
    I have the same problem. I succesfully manually updated the access points to the most current software, 6.4.4.0-4.2.3, but the virtual controller still cannot access the update server for some reason. Checked the firewall, I don't think the problem is there,  So what else should I check?
    Thanks!
    David
  • 11.  RE: Aruba IAP 205 - Received no response from server
    Posted Oct 29, 2016 06:01 PM
    The code you have is early access code. There is no newer GA code than the one you have.
  • 12.  RE: Aruba IAP 205 - Received no response from server
    Posted Oct 30, 2016 08:00 AM
    I understand that, but why would the update server not respond at all?
    Thanks -
    David
  • 13.  RE: Aruba IAP 205 - Received no response from server
    Posted Oct 30, 2016 08:19 AM
    That is a good question.  Can you even ping device.arubanetworks.com?
  • 14.  RE: Aruba IAP 205 - Received no response from server
    Posted Oct 30, 2016 11:01 AM
    This is from the master, connecting through the virtual controller IP.
    84:d4:7e:c3:80:8e Sales# ping device.arubanetworks.com
    Press 'q' to abort.
    PING device.arubanetworks.com (104.36.249.201): 56 data bytes
    64 bytes from 104.36.249.201: icmp_seq=0 ttl=49 time=54.0 ms
    64 bytes from 104.36.249.201: icmp_seq=1 ttl=49 time=54.3 ms
    64 bytes from 104.36.249.201: icmp_seq=2 ttl=49 time=54.0 ms
    64 bytes from 104.36.249.201: icmp_seq=3 ttl=49 time=54.0 ms
    64 bytes from 104.36.249.201: icmp_seq=4 ttl=49 time=54.0 ms
    --- device.arubanetworks.com ping statistics ---
    5 packets transmitted, 5 packets received, 0% packet loss
    round-trip min/avg/max = 54.0/54.0/54.3 ms
  • 15.  RE: Aruba IAP 205 - Received no response from server
    Posted Oct 30, 2016 11:45 AM
    I would open a tac case if you are really concerned about that.
  • 16.  RE: Aruba IAP 205 - Received no response from server
    Posted Jan 03, 2021 11:06 PM
    Hello there
    could you help meow pls too.  I have two aruba aipn215 access point that i use inside my house.  instant virtual controller shows that the firmware running is 8.4.0.5_72830.   I am also getting "received no response from server" when i click the check for new firmware button.   do I need a new certificate uploaded  if yes where can i get that?  thanks
    Nilesh Patel
  • 17.  RE: Aruba IAP 205 - Received no response from server
    Posted Oct 08, 2015 10:18 AM
    Hi
    I've got this build but the exact same problem.
    6.4.2.0-4.1.1.0_45444
    I didn't get the solution though.
    PS: 215 IAPs
  • 18.  RE: Aruba IAP 205 - Received no response from server
    Posted Dec 22, 2015 04:46 AM
    Same here please help
  • 19.  RE: Aruba IAP 205 - Received no response from server
    Posted Dec 22, 2015 06:30 AM
    What is your problem?
